CR11S-CS968 (8188 Wifi Works) TV01, 1080p GT-19300 (G3 Spoofed) 2MP/5MP 6210 (Built IN NEW Video Mix App) "BeYond XBMC" READY
    1080i fix
    Originally posted by Tech1 View Post
    I will look into this for you ...! Let me know which Finless ROM has 1080i ...!
    this guy said that he used finless rom 1.7 on mk808b to have it play on a 1080i hdtv.
    "I managed to get the TV to recognize the MK808B by flashing Finless ROM 1.7. I had previously tried 2.1 with default 720p resolution but the it did not work. Not sure why, but for the time being I will stay with 1.7."
    Thanks for all the help
    Alex
      8188 (wifi works)
      Just wondering the title of this thread said "(8188 wifi works), what is 8188???
        It is the wifi module mounted on the PC board.
        There are some variants such as AP6210.
          It is the Realtek 8188 WiFi chip set.
          JDfense --->I8160
            Thanks a lot for this great ROM, Tech1.
            Question: was it designed for full 1080 support or should I expect some slow response from the box when in 1080?
            Beyond XMBC plays all of 1080 movies with a bit of jerking here and there, and in some movies it pauses for a split second after every 5 -6 sec. MX player delivers a bit more enoyable playback, but there is a bit of jerking as well.
            Am I the only experiencing these issues?
            Is there any remedy?
              Everything should playing smooth as silk ..! Are you using the "Beyond XBMC" found Here http://www.androidfilehost.com/?fid=23329332407569668 ....?
                Thank you Kakashi and JDfense. I'm ordering a new CR11S and should be here soon, so I have to crack open the brand new box to see the wifi module or can I see it some where in the settings??
                  Yes you have to open the box to see what chip you have.
                    Possible to see Wifi/CPU chip set without open the box!
                    Hi all,
                    I found 2 apps that can detect the wifi/cpu chipset without open the box up. I tested on a few devices 3066 and 3188 and it works well. I just need someone with the CR11s or CS968 (since I don't have either device yet) to run the app to see if it reports the correct chip set.
                    For Wifi chipset - app name is Wi-Mark: reception benchmark (just search for wi-mark in play store).
                    For CPU chipset - app name is CPU/RAM/DEVICE identifier. (just search for cpu/ram in play store)
                    Thanks in advance
                      Clean install of this ROM usiing Beyond XBMC Beta3.3 = 720p super, 1080p 6-7fps drop :-(
                      Even tried many nightly and monthly builds, but results are worse!
                      The best XBMC i ever tried is XBMC for MiniX Beta 2, buut still gives me 4-5fps drop on 1080p videos!
                      Is there any way to o/c gpu and ram since we cant do anything on 3188T cpu?
                        Minix xmbc wont run on hardware excel on anything but stock Minix ROM I would look at video settings and something hardware excel releated.
                          Hi all,
                          Thanks in advance
                          Tried Wi-mark doesn't display right chipset.
                          Tried CPU/RAM/DEVICE it did correctly identify the cpu as 3188
                          Surprised to see it clocked at 1.42 ghz
                            There is a modded version for Galaxy S3 spoofed roms!!!
                            What video settings you sugest?
                              MK902
                              I love this ROM! I'm running it on my MK902:
                              CR11-CS968_GT-19300_1080p_5MP_6210_OpenVPN_LibMedia.so 20140127_update.img
                              with the newest:
                              Beyond XBMC Beta 3.3
                              Anyone one know of a open recovery that works with this combination? I'd love to have a backup when flashing ROM's that weren't designed for my model!
                              Rikomagic RKM MK902-16G RK3188 Quad Core Cortex-A9 1.6GHZ, Android 4.2, 5MP Camera
                              Last edited by Aircraft800; 12 February 2014, 09:27. Reason: Newer version found, thanks!!
                                with the newest:
                                Beyond XBMC Beta 3.1 (GT-I xxx).apk
                                3.1 isn't the newest anymore mate. 3.2 and 3.3 have been out for over a week and doesn't require any spoofing any more.
                                To Infinity and Beyond.... XBMC
