Thanks you.
CR11S-CS968 (8188 Wifi Works) TV01, 1080p GT-19300 (G3 Spoofed) 2MP/5MP 6210 (Built IN NEW Video Mix App) "BeYond XBMC" READY
Originally posted by raul81 View PostI have an CS968 RK3188 ver.3 but i don't have an MT5931 Wifi and MT6622 Bluetooth. , my wifi/bluetooth one chip is AP6210, this rom is ok for my device?include the driver for AP6210 or not.
Thanks you.
same mainboard
Thanks you.).
New VideoMix-2 App Released
Their is a NEW "VideoMix-2 App" just released, that can be found in the right hand column in the bottom blue link download section HERE https://plus.google.com/communities/...artnerid=gplp0 .....Last edited by Tech1; 02 February 2014, 07:18.
Hi Tech1,
Does your ROM CR11S-CS968_GT-19300_1080p_5MP_6210_OpenVPN_LibMedia.so_20140127 ROM include the frame skipping fix for RK3188?
Thank YouFor all your computer problems...
http://www.salvamipc.es
Thank You
Originally posted by Tech1 View PostIf you are referring to the "Beyond XBMC" yes ... Personaly, I have never experienced any frame skipping ...
http://www.freaktab.com/showthread.p...-rk3188-kernel!For all your computer problems...
Originally posted by smic717394 View PostI mentthe problem that RK3188have with the vsync.
http://www.freaktab.com/showthread.p...rk3188-kernel!
Originally posted by Kakashi View PostAs subject
But there is a strange thing that my wifidisplay cannot work with Nexus 7 (2013) which is Android 4.4.2.
The link got broken after the source device is connected.
Anyone know how to solve?
*8188 CS968 (Wifi Works) Pre-Rooted
Get the NEW ROOTED 8188_GT-19300_htc_t018_public_Mtk_20140127 HERE http://www.sendspace.com/file/4z0woo ....
The Wifidisplay is not working between Nexus7 and CS968.
Did not know why yet
Originally posted by Tech1 View PostHave you ever had the Wifidisplay working with any device ...? Also using the above ROM build does the WiFi work ...?
I tried wifidisplay when I got the box
but I did not have the ROM image come with the box.
(means there is no way back to factory default)
And I had Nexus 7(2013) to test with, so I did not know whether the problem exist between Android 4.2.2 (CS968) and 4.4.2 (Nexus 7) or not.
Those ROM images with AP6210 failed to have both wifi and BT, so wifidisplay cannot be tested.
I wonder those who have the CS968 with the mentioned 8188 ROM have any luck in working wifidisplay or not.
Excellent rom
The best rom i have tried until today. Nice work .
I would like to ask if it is possible to configure the rom to have 1080i output because i want to connect it with an old LCD TV which does not support 720p or 1080p. I have heard of similar problems for android TV sticks that have been solved in the finless roms.
Thank you TECH1 for the nice work
Alex
Originally posted by azafeiros View PostThe best rom i have tried until today. Nice work .
Alex
There are currently 2075 users online. 1 members and 2074 guests.
