CR11S-CS968 (8188 Wifi Works) TV01, 1080p GT-19300 (G3 Spoofed) 2MP/5MP 6210 (Built IN NEW Video Mix App) "BeYond XBMC" READY
3D SBS
Anybody knows a good player for playing 3D SBS movies, i tried allot of programs and none good. On the tab i have the 4KPlayer that was preinstall, and with this progrs 3D is great, but unfortunatl I can instal it on any devic, will install but as soon as I open, the rogram closes.
ThanksFor all your computer problems...
http://www.salvamipc.es
Smooth play dependent on chipset?
Originally posted by Tech1 View PostEverything should playing smooth as silk ..! Are you using the "Beyond XBMC" found Here http://www.androidfilehost.com/?fid=23329332407569668 ....?
Hi Tech1, I get the same frame drop/loss that others have been reporting with the Beyond XBMC referenced - 3.3.
Not sure if this has been discussed anywhere else but after running CPU/RAM/DEVICE identifier my supposed 1.8 Ghz device is capped at 1.416Ghz. CPU type: Rockchip RK3188 x4 1.6 Ghz at 1.416Ghz. I am wondering is thus is the reason for frame dropping with vid playback?? Have you run the CPU/RAM/DEVICE identifier to get your devices specs?
Wishing I could get the 'smooth as silk' video play back which I am thinking may be a hardware issue(RK3188T). Can anyone confirm this? FYI, my device is a Cloudnet CR11/S 2MP cam.
Flumpster, really been enjoying Beyond XBMC 3.3, very stable.
Originally posted by toose View PostHi Tech1, I get the same frame drop/loss that others have been reporting with the Beyond XBMC referenced - 3.3.
Originally posted by ma_trix View Post@Tech1
Do you have overlock kernel to Rom
8188_GT-19300_htc_t018_public_Mtk_20140127
I have v3 versions of the device, the processor without T. Antuntu shows 1.4 Ghz. I do not know why?
Originally posted by JDfense View PostI know the 4k player from my Allwinner tablet. It seems not to use for Rockship devices.
JDfense --->I8160For all your computer problems...
ShowBox And VideoMix New Updated Current Versions
Get the NEW UPDATED ShowBox And VideoMix apps New Current Versions found HERE https://plus.google.com/communities/...artnerid=gplp0 ...
There are currently 2066 users online. 1 members and 2065 guests.
