RKM MK902 - Neomode Custom Rom Version 1.0
    Nice one. Which kernel is this, and what settings?
      Maybe you guys should read this...
      http://www.freaktab.com/showthread.p...-make-your-own This might help you guys. Seems like a noob with help from senior members figured out your problem. In particular pay attention to the script... Hope it helps
      @µ$ł!Ω
        Thats Simic 1666 from his post its fast and clean running fast tested beyond and all working as well, its running warm but not really going into danger zones, i put side mount fan and ran the 1.9 and it booted and ran so ill try once i get the fan kits and heat sinks for the cpu and ram chips, looking promicing. glad to see it not the T chip
          Ya look at last post we have new 1080p software but re packing it is being a bitch and its not booting once its re packed so asked Ro for some help with it. i dont know what else to do tried changing boot img and kernels so kinda stumped at what to do next is all.
          Smic in same spot.
          Sorry Neomode but i also sould have asked for your help as well, seeing as this is your Thread (Lack of respect on my end sorry...)
            Thats the 667 mhz for ram kernel? but you changed the cpu to 1.9?
            http://www.mediafire.com/download/f9...666_vsfsam.img this one?
            BTW that usb to pc is buggingm now it doesnt connect anymore, it did just before. Pff. Have to toggle a little on ''connect to pc'' than it works.
              Scoot... I know this is off topic but what heatsink/fan are you using? Im trying to find one smaller than my old pc's northbridge heatsink/fan but am having trouble.
              @µ$ł!Ω
                Or raid your local electronics recycling place, I did a run last week and got about 20 different types and its just a matter of cleaning them up and re using I like those finds as i am a cheap ass when it comes to getting parts lol
                  Thanks bud!
                  @µ$ł!Ω
                    Kernel1666 is CPU 1.6 GPU 600 and DDR 667
                    For all your computer problems...
                    http://www.salvamipc.es
                      Smic in same spot.
                      Ok i got it to load, it the tool. Use RK29xxImageTools_v2.1 (Wandals Tool) to extract the MK902_1080p_140114 once extracted go to TEMP folder in image and change the kernel to the one you want from the oc once i uploaded yesterday then with the same tool clock repack. will create another image that you can flash with the Rockchip Batch tool
                      Download Wendals tool from the link bellow.
                      Contribute to wendal/teclast_tools development by creating an account on GitHub.
                        Smic any luck I tried all no boot for any. maybe that 1080p rom
                          Yes, check my previous post
                            https://github.com/wendal/teclast_tools
                            Can you post a link to your final compiled rom or kernel.img. That would be greatly appreciated. Let us know how it plays 1080p and bench scores as well.
                            @µ$ł!Ω
                              HD stuttering
                              Hi all,
                              Are there any settings i should tweak adotionally for this ROM tot get the annoying stutter tot go away? It s micro but still annoying. I m running the 1600 kernel patched with vsync on a mk 802 iv.
                              Thamks!
                                Here are the OC Kernels from the stock 1080p rom all versions
                                MediaFire is a simple to use free service that lets you put all your photos, documents, music, and video in a single place so you can access them anywhere and share them everywhere.
                                Here are the most used versions of the same OC kernels with the vsynk fix as well.
                                I prefer the kernel_cpu1608h_gpustock_ddr667_vsfsam.img its CPU 1.6 GPU Stock and DDR 667.
