If you just want to try this one, you can use http://www.freaktab.com/showthread.p...ew-RK-2-1-tool to make a full backup of your current ROM first and then restore it if you don't like this one.
RKM MK902 - Neomode Custom Rom Version 1.0
Originally posted by Magnus33 View PostDoes work on the mk802IV T cpu but its limited to 312mhz- 1.2ghz regardless of kernel.
Otherwise seems fine.
me too!!
Try this http://www.minix.com.hk/firmware/NEO...i_20140211.rar Works great
Originally posted by neomode View PostThanks for your comment. I have done my best for a good Rom.
Neomode
So im back to 2.1 beta, the best fit for my stick except the ******* gpu of course!
Any news for non-beta release?
AW: RKM MK902 - Neomode Custom Rom Version 1.0
Originally posted by babnik80 View PostSo, i tried it on my mk802iv, it works fine but, i could't oc the ram, whatever kernel i tried i was getting 445 ram speed in dmesg. The cpu was at 1800mhz with 312 and 1200 scale, and the gpu as always locked at 446. I am getting dissapointed from rikomagic, espesially with the gpu problem. Neomode, can you do something with this gpu thing, or i must forget it?
I think it it's better to oc the Ram because the GPU use also the Ram.
Neomode
Excelent
Hi Neomode,
I just want to say thank you for this great rom. My MK902 have a problem with random restarts, anyways I have been using I for over a month with your 1.9a ROM and the kernel from CRS11 and I had no issues with random reboots.
I installed this rom you have for the MK902 and been using it for the past 4 hours without any problem. The Wi-Fi works, camera wok, Bluetooth works. It looks great thank you.
The only issues I could find are
1. Video playback it’s a bit choppy. Is the kernel patched with the RK3188 vsynk fix?
2. I tried to play a 1080p movie on the XBMC version included and it’s very slow, I don’t think the hardware acceleration works at all.
Thank you.
For all your computer problems...
http://www.salvamipc.es
neomode;148924]Let me ask why is OC of the GPU tho imported for you ? In the MK902 Rom I have overclock the GPU. But also important is overclock the Ram.
Neomode
Gesendet von meinem GT-I9305 mit Tapatalk 2[/QUOTE]
So, I saw the dvfstree in dmesg and I discovered something more, at my mk802iv I can't even oc the ram, it's stuck at 450mhz!
Neomode please help before I break this damn thing. You have the same stick, can't you test it?
I just wanted to add my experience with this rom as it differs from you. I am using the new Beyond XBMC beta 3.3 and it looks like hw accl is working for me. 1080p with dts 5.1 going out optical port to my a/v receiver and let me tell you, best android/xbmc experience for me to date! Only issue i could find with 1080p playback is trying to stream them over wifi. I switched to lan and all is well. Or usb fixed this too. The wifi on these little boxes just arent very robust I guess.
Thank you.
XBMC
No luck here with xbmc. I tried the latest nighty xbmc, I tried Beyond XBMC beta 3.3 and the SPMC that came preinstalled and the same result, very sluggish. Playing the videos with MX Player its smooth. I tried the Flash it app and spoof as nexus 7 and now xbmc is a bit better but still skipping allot of frames.
With the 1.9a Firmware and the kernel from CRS11 was playing fine.
Are you using a overclocked firmware?For all your computer problems...
There are currently 2095 users online. 0 members and 2095 guests.
