RKM MK902 - Neomode Custom Rom Version 1.0
    Re: RKM MK902 - Neomode Custom Rom Version 1.0
    Originally posted by smic717394 View Post
    You returned the X7 for MK902? I would gladly exchange my MK902 fot the X7... What was wronf with the X7?
    I thought it was overpriced. So I got mk809iv which was junk. Then decided if I'm gonna pay over $110 its gotta have a camera.
    Sent from my VS980 4G using Tapatalk
    Donations--> Paypal
      Now that that vie been playing with for week or so it's growing on me for 100 it's not a bad box, adding heat sink fans are bit of pain but it's still working good.
        Was it overheating n freezing? Where u get the info for the heatsink?
        Donations--> Paypal
          Ya once I go past 1.7 starts to get hot, after bit things start to degrade from heat so I put small usb fan just hooked to bottom and stood on side, now that I have the other box open the stock heat sink can't mount fan to it so ordered one from site,
          having fan made 1.7 stable 1.8 boots but really hot lol.
            Did ur new boxes come with the USB male to male cable?
            Donations--> Paypal
              did you managed to use the kernels. I tried anything using neos rom and just use the kernel still the same. Ill try to repack later from a xp machine
              Sent from my GT-I9300 using Tapatalk
              For all your computer problems...
              http://www.salvamipc.es
                yes same here i tried with both boot replaced and kernel from neo as well as changing the kernels in each one but stuck at boot logo 1.6 booted then froze at launch screen
                going to try and load a different way today maybe i did something wrong, THE NEW ROM LABLED AS WENDEL NEW SO think i may have flashed wrong file ill try again in few
                  No luck all fail on boot, changed boot.img and got a boot but froze.
                    we missing something on the repacking or maybe on extraction. I tried to flash the rom just after the extraction without modifications and the same...
                      Did a new antutu with kernel @81 score is 18086 :-)
                      Sent from my Lumia 920 using Tapatalk
                        Il try later with wandals tool
                          By the way, when i connect via cable USB its a ADB device, how can i change this into it being a mass storage so i can acces it via laptop?
                          In hardware it shows up as ADB and 2 times a USB device but i cant acces it.
                            Turn off usb debugging in settings and set usb connect to pc in usb settings should work. Nice score i got less with that one running a few to test waiting to see if we can get the new firmware with oc kernels now....
                              Yea forgot that one! lol, thanks. Its a bit different for me, just getting used to android! ;P
