RKM MK902 - Neomode Custom Rom Version 1.0
yes i want to oc that kernel so i can see if it runs with 1080p is all. as i thought the vid fix was in the overclockomatic software as well, i read the post in overclockomatic and he used 6,7,9 as it was the higher value? 4 isnt the ddr is it?Many devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
Hi Neo
I tried both 8 and then 9 but got the same error message ERROR:the DDR table is larger then the DDR table in the Kernel? The new 1080 software boots and runs at 1.4 and kinda flacky but if i can patch to 1.6,400,667 maybe it will work fine/? I dont think its a T as i can oc to 1.8 your kernels.Many devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
Originally posted by scooter2014 View PostHi Neo
I tried both 8 and then 9 but got the same error message ERROR:the DDR table is larger then the DDR table in the Kernel? The new 1080 software boots and runs at 1.4 and kinda flacky but if i can patch to 1.6,400,667 maybe it will work fine/? I dont think its a T as i can oc to 1.8 your kernels.For all your computer problems...
http://www.salvamipc.es
Originally posted by micromod777 View PostJust returned my Minix X7 mini to Amazon ro get the MK902 for the camera. How the camera on this ROM?
Sent from my VS980 4G using TapatalkFor all your computer problems...
Originally posted by scooter2014 View PostI am trying to but cant get past that error message is all.
The camera is ok nothing special...For all your computer problems...
kernel.zip ok i only have windows heres the kernel out of that 1080p rom.
Thanks in Advance.Many devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
Originally posted by scooter2014 View Post[ATTACH]5710[/ATTACH] ok i only have windows heres the kernel out of that 1080p rom.
Thanks in Advance.
Originally posted by scooter2014 View PostAwsome these kernels are from that 1080 rom? Thanks I'll test them tonight,For all your computer problems...
I unpacked the MK902_1080p_140114 using RK3xxx_firmware_tools, I manage to pack it back into a img file, and reflash it with Rockchip_Batch_Tool but its stuck on the Android logo. I also tried to use the unpacked img and flash them using RKDevelopTool but the same.For all your computer problems...
1080 or 720 HD still stuttering what am i doing wrong?
Hi all,
Neomode thanks first off all for the great ROM!
Many of you solved the stuttering problem.
Mine is still driving me up the walls :-)
I have a MK 802 IV with neomode 1.0.
I tried several kernels even with the vsync path applied but still the same problem.
The best running is now the 1600 kernel with the vertical sync patch included.
I got MX player set up with the latest arm 7 codec and running hw + and dept color 10+
Any ideas how i can solve the stuttering would be greatly appreciated!
Originally posted by smic717394 View PostI unpacked the MK902_1080p_140114 using RK3xxx_firmware_tools, I manage to pack it back into a img file, and reflash it with Rockchip_Batch_Tool but its stuck on the Android logo. I also tried to use the unpacked img and flash them using RKDevelopTool but the same.
will try with same kernels and replace boot.img with neomodes?Many devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
There are currently 2186 users online. 0 members and 2186 guests.
