RKM MK902 - Neomode Custom Rom Version 1.0
    Originally posted by neomode View Post
    Just flash my Rom with the 1.7 GHz Kernel.
    Neomode
    I don't know, but I maybe blind or something, but I don't see 1.7 GHz Kernel.. Can you tell me how exactly is written in the folder? Thanks
    -Chromecast with Google TV
    - Android Q Android 10
      AW: RKM MK902 - Neomode Custom Rom Version 1.0
      Will answer you today later how to flash it.
      Neomode
        Fixed it.
        First -> Run the TOOL -> Switch -> It will loose the RKM device, afterwords it can't install a driver so: (Install the driver included in tool/rom download) -> RUN -> Done.
        This rom feels slower then the original one, and the splash loading takes so long.. -.-
        Antutu scores seems higher though 17899 now. ;D
        Also when flashed, i cant connect it with the usb anymore (it wont come up on my PC anymore) Also it says available space 3.28GB i have a 16GB nand, where is the rest?
          Beyond XBMC on Rikomagic MK902
          I have Beyond XBMC Bet 3.3 installed on my MK902, so far picture perfect image for HD (1080), it works great. Only problem that sometimes it won't let me enter any option or addon on the main menu, I have to stop XBMC and reopen it from the Settings option of the MK902, it is as if it locks the application. I tried, enable and disable every option in xbmc, but so far after 2 weeks it is still there. What can I do? Thanks in advanced
            Neomode
            I know how to flash Kernel, but I don't see 1.7 Kernel on my folder...Can you please share 1.7 Kernel? Thanks
              I use this one.
              Works good with this rom and XMBC 3.3 beta.
              Sent from my Lumia 920 using Tapatalk
                That kernel is 1.6
                  Yes, but its good.
                    [QUOTE=INFIN1TY;154106]Yes, but its good.
                    It's ok lower antutu score thought I just testing beyond and few othrs where this kernel from cr11s?
                    it scored low 17000 that's why I want to try the 1.7 or 1.8 I try to oc this build and see
                      My antutu was 17899 with this kernel. I think 1.77 is the one in the download folders. (i think) but i stick to this one. No issues.
                        Running beside different build beyond darker and not as fluid 2tv side by side it' seems a lot darker I switched hdmi and same on the other tv
                          It is smooth and running with no artifacting I like it so far having an issue with super su so going to re flash again
                            I don't like the splash logo intro for the rest its awesome. Thnx Neo
                              I used boot animations and installed tat mans freak tab one and put some new wall papers but notice there are boot options and freak tab browser ect nice job on those the rom runs smooth and nice ad dons included well done,,,,
                              update tee getting some bad artifacting 10 minutes into movies. 720p and ice films mega data fail
                                I have zero issues. Use gotham latest build
