Official CS968/CR11S (2MP/5MP 1080p) Ultra HiDef Video Enhanced {Best ROM To Date} AP6210 ("BeYond XBMC READY")
Tech1, I just found out a big issue, my pc can communicate with my device fine, but after I flashed your super/4k video rom, my pc no longer can see my device anymore, either in usb mode or download mode. Do you have any suggestion?? the only way I see right now is to find a zip flashable rom so I copied to my sdcard and flash with CWM. I really want to try out the ultra highdef rom but there's no way for me to flash it... Thanks
Originally posted by buhohitr View PostTech1, I just found out a big issue, my pc can communicate with my device fine, but after I flashed your super/4k video rom, my pc no longer can see my device anymore, either in usb mode or download mode. Do you have any suggestion?? the only way I see right now is to find a zip flashable rom so I copied to my sdcard and flash with CWM. I really want to try out the ultra highdef rom but there's no way for me to flash it... Thanks
Originally posted by Tech1 View PostMost likely you have a driver issue and go to Settings> Developers option, check mark USB debugging .... Go to Device Manager on your PC, make sure your drivers are installed correctly ...
Originally posted by Tech1 View PostMost likely you have a driver issue and go to Settings> Developers option, check mark USB debugging .... Go to Device Manager, make sure your drivers are installed correctly ...Last edited by buhohitr; 04 March 2014, 06:05.
The best rom to date - Review
REVIEW Update: I flashed the rom, update xbmc to version 3.3. The resolution is the killer of all cs968 rom, the rom itself is much quicker and xbmc is faster also. Wifi, ethernet, bluetooth, all working well. Phone remote control/wireless mouse/keyboard are working well too. Showbox is also pretty smooth (version 2.5 latest). It deserved its name "Ultra hidef". This is the best rom for me to date, being running this for 1 day and zero issue so far. I also tested streaming HD over wifi and it perform well, pretty smooth. When test wifi hd streaming, make sure you select a good source, most people think it's the xbmc issue but it just a poor source. I also setup xbmc to cache to sdcard, where if I have no choice to use a slow source, I let it buffer 75% of the movie to the sdcard before I start play back - never have "cache full message anymore). This rom just make me feel that I do have a true multimedia center, my kids are impressed. They think their daddy is a genious, that bring a high-def resolution movie theater to the living room...They watched from movies to TV shows and it performed flawlessly (from 9am to now 10pm). I just love this rom, not much more to say..flash it now and enjoy!!
Originally posted by fespafer View PostHi! Thanks for your time doing this ROM for our device which are short of them. Is that ROM prerooted? . Is i your mind overclocking the kernel? Since it's a rk3166 it could work at 1.8Ghz without problems I think. Thank you again for helping us.
Originally posted by buhohitr View PostREVIEW Update: I flashed the rom, update xbmc to version 3.3. The resolution is the killer of all cs968 rom, the rom itself is much quicker and xbmc is faster also. Wifi, ethernet, bluetooth, all working well. Phone remote control/wireless mouse/keyboard are working well too. Showbox is also pretty smooth (version 2.5 latest). It deserved its name "Ultra hidef". This is the best rom for me to date, being running this for 1 day and zero issue so far. I also tested streaming HD over wifi and it perform well, pretty smooth. When test wifi hd streaming, make sure you select a good source, most people think it's the xbmc issue but it just a poor source. I also setup xbmc to cache to sdcard, where if I have no choice to use a slow source, I let it buffer 75% of the movie to the sdcard before I start play back - never have "cache full message anymore). This rom just make me feel that I do have a true multimedia center, my kids are impressed. They think their daddy is a genious, that bring a high-def resolution movie theater to the living room...They watched from movies to TV shows and it performed flawlessly (from 9am to now 10pm). I just love this rom, not much more to say..flash it now and enjoy!!
Originally posted by Tech1 View PostYes, it pre-rooted (rk3188), but I will never ever build a overclocked ROM ...!
Originally posted by fespafer View PostOk. Thanks for your fast answer. Just let me ask you one more question. Do you know how could I install a compatible custom recovery for this device?. I can't find it and don't know how would I install it neither. I want to be able to make backup via recovery and some other functions. Thanks again!
Originally posted by Thracia View PostGoogle for cs968-cwm-recovery.img.zip and term-install.zip.I think you can found it inside the forum. Then you will need a terminal commands.send me pm if you need more help.
Originally posted by fespafer View PostDoes it woks for my Cr11S 5mpx can?. Thanks for your help. I'll search on the forum and see what I can do.
There are currently 6377 users online. 4 members and 6373 guests.
