Otherwise, I'm afraid it's a hardware issue. These Pipo tablets have a highly sensitive voltage regulator/battery protector chip...and it fails quite easily.
Pipo M9 Pro RileyROM 2.6 KitKat
Try pressing the power button for 15 seconds. See if that hard reset will fix it.
Otherwise, I'm afraid it's a hardware issue. These Pipo tablets have a highly sensitive voltage regulator/battery protector chip...and it fails quite easily.Randy
USP DAC not working...
FYI: External USB DAC no longer work with the new kernel from ROM 404. It is working with the RileyROM 2.6 default kernel.
There is another new ROM by the way.
I don't know the difference yet. I might try it just to see if that is going to help the external DAC issue.
EDIT: Forget this, my bad, I was using the wrong settings... The USB External DAC are still working with this Kernel!Last edited by jy_p; 07 April 2014, 01:57.
Re: Pipo M9 Pro RileyROM 2.6 KitKat
Originally posted by jy_p View PostFYI: External USB DAC no longer work with the new kernel from ROM 404. It is working with the RileyROM 2.6 default kernel.
I'll stick with this current new kernel unless I find a real problem with it for my particular usage.
LDN
Sent from my Galaxy Nexus using Tapatalk
Shutdown on standby..
Hello guys...
Firsty congrats for your great rom.. Generally im for sure not happy from my pipo and i will not buy this brand again but im having this right now and thank god we have you and your roms so it makes it a bit better...
i have a problem last days.. My pipo shutdown on standby fuction... Per example im leaving it for half an hour on standby and when i try to open it its just close... this happened 3-4 days ago and then i decided to restore it and i made the procedure again putting the new kernel... still same problem as before.. any ideas? do you think this could be a hardware problem? thanks in advance!
Originally posted by LazyDogNet View PostI think that is the one called a "Brushed" version that you need to flash a particular way... I could be wrong though. I saw it a couple of weeks ago and thought it looked more trouble than it was worth.
LDN
Would be interesting to hear feedback about this new ROM...
Has anyone tried it?
I went ahead and flashed the kernel. Tab seems happier than ever
Cheers.
There are currently 2240 users online. 2 members and 2238 guests.
