Pipo M9 Pro RileyROM 2.6 KitKat
    Re: Pipo M9 Pro RileyROM 2.6 KitKat
    Originally posted by kostasd View Post
    There is no GPS.conf file inside /system/etc
    But there is a /system/etc/GPS/gpsconfig.xls
    I don't know whatnis this !!!
    Me too, so gps.conf is useless as I never had GPS problems without it
    Sent from my M9Pro using Tapatalk
    PROUD owner of PiPO M9 Pro
    PiPO P9 best tablet ever owned!!!
    PiPO Tablet Freak and Flashaholic!
      Download the app fasterfix. Then you can choose te country you need. it's the most simple way.
        even with fasterfix it doesn't work
        Sent from my GT-I9300 using Tapatalk
          For me it did help!
          This Rom is fantastic, Thank you riley. I bought you some more bier
          Antti
            Hey randy why did you removed gmail from the rom? I had to manually install it
              On some ROMs, running Gmail as a system app causes errors. It happened on this same ROM on the M7 Pro, so I removed it this time. That's all.
              Randy
                The battery drains fast on this KK rom. I wish it lasts longer like when i was on JB 4.2.2
                  I fixed this on my wifi only tablet by turning on airplane mode an then turning back on wifi...
                    Change launcher
                    Originally posted by Starcopy View Post
                    No, it's the fault of the stock launcher. Take another one like apex or nova.
                    Can someone point me to instructions on how to find and change the launcher? Thanks.
                      Go to the playstore and search for nova or apex. Install it and make that your default launcher. Thats it.
                        Wow! Thanks! How simple is that!?
                          Why has this thread moved to folder "Archived Pipo ROMs"?
                          Is there a newer one available?
                            Sorry...my bad. Ill move it back.
                            Randy
                              Originally posted by manao View Post
                              Hello Randy. I find on BBS Pipo a new KitKat update for the M9pro.
                              DS1007_4.4.2_#404_20140319
                              M9PRO_#404-4.4.2
                              The kernel is dated from 19 march
                              I uploaded this ROM on mediafire : http://www.mediafire.com/download/ef...0%E7%89%88.zip
                              Extract and go to folder ROM and Image (inside image it is already unpack like your ROM: kernel.img / boot.img. / system.img etc...)
                              I decided to play around a bit and flashed the kernel from the above ROM to Riley's 2.6 ROM on my M9 Pro.
                              No issues flashing it and it now show that I have 1608Ghz available. I ran AnTuTu and my score jumped about 1800 points to just a little over 20000. I can't say if I really notice any difference in performance though. Also, I haven't done much testing to see if anything is not working as it should, but nothing obvious is broken.
                              LDN
                                Wow, I guess I totally missed that new firmware post.
                                I will download it and take a look.
                                Randy
