how do i flash a new twrp recovery? i tried with flash tool but all i see is green robot with red triangle
Pipo M9 Pro RileyROM 2.6 KitKat
I have tried TWRP on my device and it wont respond over touch screen.
However evertinhg you want to flash,you can do it with the 2 flashtools.
I think you are bricked now.
If after flashing TWRP you see the Android...you DIDN'T FLASH TWRP.
Check the flash tool settings and make sure you did it right. If you flash TWRP in place of the stock recovery, you won't see that Android robot anymore...you will see TWRP.Randy
You need to just follow the exact same procedure you did with the other ROM. Yes, you need to erase IDB. And keep the loader checked because this is a new loader.bin file.Randy
Cool
Originally posted by rrileypm View PostYou need to just follow the exact same procedure you did with the other ROM. Yes, you need to erase IDB. And keep the loader checked because this is a new loader.bin file.
Can someone tell me if the device goes down to deep sleep with this rom?
Both RR and Finless i have tried (JB base) have always reported 99% wake state, according to "wakelock detector"
Only rom that i have seen and tested that lets the device go to deep sleep is nxmod/kkmod.
Im looking for a KK rom and this seems to be it but i dont want to go through the hassle of updating and then realize the device is awake all the time and have to charge 2 times / day.
Re: Pipo M9 Pro RileyROM 2.6 KitKat
Originally posted by Zeggi View PostCan someone tell me if the device goes down to deep sleep with this rom?
LDN
Sent from my M9Pro using Tapatalk
Originally posted by LazyDogNet View PostYes, it does (according to a few different CPU/Kernel modification and monitoring apps I've tried so far). The only CPU state mine shows it doesn't use is 1608MHz ....which is a real shame, but many others are in the same boat.
LDN
Shame about 1608MHz but as long as its responsive and goes down to deep sleep im fine with it
LDN
This rom sounds fantastic! Can't wait to try it out when my m9pro arrives this week (hopefully). I have a few questions..
Riley you say multi screen feature isn't available is that just for this rom or is it a kitkat thing in general?
I haven't seen anyone comment on hdmi can someone please give me some feedback on this and if it's working as it should be? I will be using hdmi quite frequently so need to make sure this feature is working perfectly before flashing, thanks.
Multi Window was a feature in JB that hasn't made into any KK release I've seen.
As for HDMI, I haven't tested it on my M7 Pro (Which is what this ROM is based on).Randy
There are currently 7551 users online. 1 members and 7550 guests.
