Another question: I can not find a multi-window option? Is it not In this rom?
Pipo M9 Pro RileyROM 2.6 KitKat
Sorry, no multi-window in KitKat.Randy
GPS FIXED
Originally posted by M9ProPipo View Post- Hold it in portrait mode, camera on right
- Intsall and run ntpsync
- Calibrate the compass by rotating/cartwheeling on all 3 axes
- Sit outdoors somewhere without obstructing trees/buildings
- Once you have a fix keep it going for 30+ minutes to download the updated almanac from sats
But I would appreciate very much that the WifiDisplay was resolved since I bought the Miracast pen exactly to use with this device.
Appreciate all the effort and help,
Best Regards
I've only had the Pipo M9 Pro for a couple of days now, but I wanted to say "Thanks" for supplying this Kit Kat ROM and the great detailed instructions.
Just as a few other people already mentioned, I too also noticed that my kernel showed it wasn't using the 1608MHz speed.
I just did a quick test using Trickster MOD app. First I set my maximum speed to 1608 and ran An tutu. My score came back as 18146. I then set my maximum speed to 1416MHz and got a 18122 benchmark. I then selected 1200MHz as my top speed and got a score of 16460.
Since both the 1416MHz and 1608MHz gave the same antutu score, I have to think that either the 1416MHz or 1608MHz speed step isn't really in play here.
I read on an earlier post that someone said their top antutu score was about the same with both 4.2.2 and 4.4.2, so it might be that the 1416MHz step is the one that really doesn't exist, but it would be nice to verify that we're not missing our top possible speed for some reason.
Any ideas on how to test or verify this?
Mind you that I'm not complaining about this ROM in anyway, but I'm curious about it.
LDN
IMMERSIVE MODE - SOFTWARE OVERLAY PROBLEM
[QUOTE=erik90;156863]Originally posted by rrileypm View Post
Yes, xposed modifications is perfect for users who wants to add features in stock roms.
I would also recommend Gravitybox which is working perfectly on your custom roms, adds tons of customization!
Link: http://forum.xda-developers.com/show....php?t=2554049
XHaloFloatingWindow is great too ;-) multiwindow is running ok.
3g - IMEI
Hi... before anything, thanks for this excelent ROM... My tablet its so smoth. does not look the same as I bought.
I flash this ROM 30 min ago. And I cant conect with my 3G. Someone has the same problem??
I dont saw my IMEI before flash this ROM but now its set 12345678
I have no signal. Its seems that this modem is not working on my pipo.
some idea of the problem?
Sorry for my english. And thanks.
could use a little help flashihg this rom
I had been using your previous kitkat ROM and flashed it without a problem. I decided to try this one because I liked the last one so much. I'm having a problem though, during the flash process it errors out during the test mode and my tablet is stuck in flash mode. I tried the alternate flash tool but none of the image files will load. Went to pipo's site and downloaded their kitkat update and flashed that with no problem. Tried to flash this ROM again but had the same problem. Flashed the pipo ROM to get out of flash mode then tried your previous kitkat ROM but got the same error. So I'm looking for guidance on where I might be going wrong and how I can successfully flash 2.6? Also when using the alternate flash tool should I load all the image files in the Riley ROM folder? Pipo only has one image file to flash so I'm not sure how it works with multiple image files. I'd appreciate any advice. Your last kitkat ROM was great so I'd like to try out 2.6.
Originally posted by LazyDogNet View PostJust as a few other people already mentioned, I too also noticed that my kernel showed it wasn't using the 1608MHz speed.
Originally posted by dantef View PostAnd I cant conect with my 3G. Someone has the same problem??
For the stock libril and how to replace it, look at this post: http://www.freaktab.com/showthread.p...l=1#post155858
Re: Pipo M9 Pro RileyROM 2.6 KitKat
Originally posted by manao View PostSet your CPU gouvernor from "interactive" to "ondemand" (with "No Frills CPU" - apply at start)
Maybe it's a physical limitation on some of these Pipo tablets?
Would appreciate to see a screenshot of your settings and stats page.
LDN
Sent from my M9Pro using Tapatalk
Change your libril-rk29-dataonly.so with the original one.
Thanks for the answear... but this file is to M9pro 3G?
I will try.
Thank you.
Shut down
Originally posted by andonisvoug View PostSame problem here. I leave it on in the morning and I find it shutoff in the afternoon.
GPS does not work.
Anything else is great. Very smooth. With original firmware I had many freezes.
Some ideas about the deep sleep?
Thank you very much for that ROM.
This Rom is Great.
Been running this ROM for 3 days with no problems. Upgraded it from Finless Bob's ROM which is also very stable.
Nice benchmarks around 18,390.
This tablet has a WiFi issue, when using it with power supply plugged in, the WiFi connect speed drops to 5 Mbps. constantly. Unplug the power supply and the connection goes back to 65 mbps. And will stay there till you turn it off.
The tablet will now charge without the screen staying lit up all night. GPS works fine as it always has.
There are some new settings I need to learn, but it's running much faster and no freeze ups so I'm very happy with the tablet now.
Awesome job my friend,
AF5DK
I'm glad you like it.
Nice to have a fellow Arkinsawyer online!!!!!!!!
Do you make it up to Springdale much?Randy
There are currently 1827 users online. 1 members and 1826 guests.
