Pipo M9 Pro RileyROM 2.6 KitKat
Can anybody please test to see if you get the keyboard moving backwards and forwards when trying to write notes on a pdf using adobe acrobat?
I get it on both the standard keyboard and google keyboard, but I am still using the DIY M7 rom with the M9 kernel.
I just want to see if it is fixed with this version.
A
Guest
Hi, yes.
Here it is the same, but also only in adobe acrobat reader.
Gesendet von meinem M9Pro mit Tapatalk
Originally posted by andrewh View PostCan anybody please test to see if you get the keyboard moving backwards and forwards when trying to write notes on a pdf using adobe acrobat?
A
screen mirroring not working in kitkat 2.6 rom
really a good rom, smooth and fast, all functions are working... less one maybe.
i cannot start screen mirroring. im using pipo m9 kitkat and a mk809iii with 4.2.2.
i can pair pipo and tvdongle with wifi direct, but when i try to start mirroring, on pipo after a few seconds i can just see a flickering windows trying to connect both wifi and bluetooth with no results.
Thanks for solution, if its a known problem, or if you can find a fix.
hi
Alex
problem - com.android.systemui
Hi Randy,
thank you very much for your work.
i have one problem... after some time i get this message:
"com.android.systemui has stopped"
maybe it is happend because i changed the Language to Hebrew? when i get it back to english the pop-up Disappeared...
do you know what is the Reason for that?
I couldn't say...never tried Hebrew. I think you will have to Google that one.Randy
Originally posted by rrileypm View PostI couldn't say...never tried Hebrew. I think you will have to Google that one.
I had simullar messages about apps ,dont know but i think its a KitKat thing ,like on Widows.
Apps designed for windows Vista or 7 wont run on Widows 8.
I think that's the issue ,in my opinion.
hi
Alex
There are currently 1800 users online. 0 members and 1800 guests.
