Pipo M9 Pro RileyROM 2.6 KitKat
    All of the RK3188's use the same file.
    Here is a link to a collection of stock libril files from the various tablets...they appear to be the same:
    Randy
      Sygic
      I have eventually took the plunge and rooted my tablet with the new rom. The only problem I am having is with the 'sygic' app. Just can't get it to work! I wouldn't mind but i have paid for the maps etc. Anyone else got this app working on this new rom
      Here's hoping!!
      Steve G
        https://drive.google.com/file/d/0Byx...it?usp=sharing
        Thanks Randy, The stock libril sorted my M9 Pro 3G. Full 3G signal & no more switching off.
        Seems the link only refers to KitKat. The M8 Pro 3G is still running 4.2.2. Does this make a difference. I'm trying to improve my 3G on this tablet.
        Regards
          Here's hoping!!
          Steve G
          Latest version didn't work for me, but managed to get the older version running.
          Regards
            Regards
            I'm using the same file on JB and KK. People have reported the patched version helps with deep sleep on wifi only tablets, but jeopardizes 3G signal on 3G equipped devices. To each his own.
            I only own wifi only devices, since Chinese 3G tablets won't work in the US...so I have to take user's word for whether it works or not.
            Randy
              So, just to confirm, after changing that libril file:
              - No more power-off
              - Much improved 3G signal
              Also, GPS is working! So this ROM ticks all the boxes, definitely a keeper Thanks Randy, your work is much appreciated!
                3G WIFI and overall Stability
                Hi, What are the benchmarks for measuring signal strength? My WiFi seems stable. 3G is stable but sluggish. Good for emails. I am using Widget Network Signal Strength by Lakshman. 3G HSPA -91dBm, WIFI -140dBm.
                Hmm tried swapping with M7P_libril-rk29-dataonly.so (renamed libril-rk29-dataonly.so) and get what appears to be a stronger 3G signal, but still reporting as HSPA -91dBm
                Anybody care to explain the differences in libril-rk29-dataonly.so?
                Overall I have a very reliable M9Pro3G compared to the JB Stock. Thanks Randy!
                  Since i replaced the file yesterday, no unattended shut down of the device and also no specific battery drain observed until now ... Great stuff 😁
                  Envoyé de mon M9Pro en utilisant Tapatalk
                    - No more power-off
                    GPS still not working for me!!!
                      Not working as can't see sats? or no option to turn it on?
                        same here, can't see satellites
                        Sent from my GT-I9300 using Tapatalk
                          Still working well for me even with the file modified. You could try to modify the gps.conf file in your case perhaps?
                          Envoyé de mon ZP998 en utilisant Tapatalk
                            Re: Pipo M9 Pro RileyROM 2.6 KitKat
                            how would the conf file look like then? I live in UK.
                            Can someone with a working GPS and living in UK send me his conf file please, I could try that.
                            sent from Pipo M9 Pro
                              I think everybody have the same default chinese gps.conf file in the Rom. I am perhaps wrong, but it is not something you will find in the tablet but on internet directly. I found one for France/Belgium, where i live, don't know where to find one for the UK, but i guess that gps configuration for chinese smartphone or tablet should make it on google... It is a simple file, gps.conf that you have to push in /system/etc..
                                libril-rk29-dataonly.so help me ) thanks )
