Polaroid PTAB7XC Ice-Cream Sandwich Tablet (Google Play Needed)
Originally posted by thebigred67 View PostThen I have no idea where to get your ROM. I followed the directions I found earlier in the tread.Last edited by thebigred67; 02-12-2014, 22:47.
Originally posted by thebigred67 View PostI found your ROM but not sure how to install? I figured it out and it installed but the play store crashes when launched. BTW It is way faster now! Thanks!!!
Originally posted by elektrik View PostIf I ever get un-buried from my work, GuessYet and I plan on taking the ROMs for the tablets to the next level....just to tease you ;-)
OT, Do you have a recomendation for a ROM to put on my HTC Incredable?
just out of curiosity, are You running the nodifoed stock or elektricity ROM (for the pmid 702c)? Last time I reflashed it on my device a few monyhs ago it worked. as for the htc, i'd do a google search for htc incredible roms-that *other* site has lots to choose from ;-)
Originally posted by thebigred67 View PostBelieve me, no rush. I am glad it runs so much faster. The Playstore reacts the same way it did when I installed it on the stock ROM and just wanted to give feedback. BTW I believe I saw somewhere in my research that the PTB 7XC isn't compatible with Playstore. I don't know why it wouldn't be compatible, maybe you could tell me?
Originally posted by elektrik View Postjust out of curiosity, are You running the nodifoed stock or elektricity ROM (for the pmid 702c)? Last time I reflashed it on my device a few monyhs ago it worked. as for the htc, i'd do a google search for htc incredible roms-that *other* site has lots to choose from ;-)
Originally posted by thebigred67 View PostI used the PTAB 7XC elekticity ROM. That is why I wanted to leave feed back about the Playstore crashing. IIRC you don't have this tablet and the ROM is experimental. Should I flash the 702c ROM?
Give that one a whirl.
Originally posted by elektrik View PostSorry, I remembered incorrectly. It's the PMID703C which is the 'sister' tablet to this one and works perfectly fine, google play and all. The only difference is that Google play will think it's a PMID703C obviously.
Originally posted by thebigred67 View PostWow!!! Thanks so much! This one seems to run even faster and zero issues with Playstore!
Originally posted by thebigred67 View PostWeird thing. The tab will sign in on my Verizon phone's hotspot it sees the hotspot but won't go online? Do I need some app for it too work on a hotspot?
Originally posted by elektrik View Postnah, thses tablets are notorious for having wifi 'issues'. i found I had to change the channel on my android to get it to woek (assuming you even have that option in your software). I always found that channel 6 worked best
Originally posted by thebigred67 View PostNope didn't pick up any of the channels.
There are currently 2075 users online. 5 members and 2070 guests.
