FNF iFive Mini 3GS MTK6592 Octa Core Android 4.4 Kitkat Retina Touch Panel Phablet Launched
No...I managed to unbrick it. But I'm hesitant to try again until I know which flash tool to use.Randy
with what did you brick your tablet ?
To make custom ROM with all forum i have read yet, i have 2 idea :
1°) make a rom with dsixda kitchen which seems to need an alternative recovery.
2°) prepare a tablet and make a backup with MTK droid tool and convert for SP Flash tool which need so to make 3GS compatible with SP flash tool.
I think that the better idea is the first don't you think ?
That's my holdup in releasing a RileyROM at the moment. No successful update.zip for stock recovery...and failure to flash with SP Flash Tool.
The brick happened when I tried flashing CWM with SPFT.Randy
OK so at the moment you don't have any solution to get alive your tab because you can't flash it with SP Fash tool ?
I think the only reason we can't use SP flash tool is the not removal battery because SP Flashtool procedure for MTK need to remove battery and you need a full ROM ?
If you want i can make a full backup with MTK droid tool and migrate for SP flash tool but i think you need to open the tab to flash it ?
On my cube 9x its enough to connect with power off, no need to remove battery.
Sent from my U65GT using Tapatalk900Supersport
freaktab developer
I've already made a full backup of this firmware...I plan on some more experimentation this weekend after I get back home from vacation.Randy
Originally posted by rrileypm View PostNo...I managed to unbrick it. But I'm hesitant to try again until I know which flash tool to use.Originally posted by mad86 View Postwith what did you brick your tablet ?
I received a message from Geekbuying support suggesting I try holding the volume- button while pressing power for 10 seconds. A different recovery interface came up in Chinese. Since I couldn't read the menu...I just tried different options until my tablet magically booted.
Sent from my SAMSUNG-SGH-I537 using FreakTab v0.1.Randy
new member
Originally posted by rrileypm View PostI received a message from Geekbuying support suggesting I try holding the volume- button while pressing power for 10 seconds. A different recovery interface came up in Chinese. Since I couldn't read the menu...I just tried different options until my tablet magically booted.
Originally posted by nightowl58 View Postthank you! Your experience was very useful for me, because i also brick my i5mini3GS .The same reason - I try to root from SD card with update.zip. Thank you very much!
version 1.1.0 bricked
Originally posted by ivivdim View PostI'm not 100% sure, but maybe you are the first one in this thread who bricked the tablet with this root method. Which is your software version (1.0.7, 1.0.9, 1.1.0)?
Виждам че си българин. Таблета не се брикна веднага.Самата инсталация на update.zip завърши,той се рестартира,проверката с Root checker показа че НЯМА руут. След минута цъфна Super User, поиска някакво разрешение, дадох му го. Проверката показа,че вече има руут. Google play i Clean master увиснаха и не искаха да се терминират. Нов рестарт и тогава умря. Добре, че прочетох поста на Ренди Райли, събудих го. Смених SD картата с друга,пак загина. Пак го събудих и оттогава вече си работи, явно пише нещо на картата. Не съм първия, в руския форум 4PDA един скимтеше, че го е брикнал ей така, без нищо да прави.
Originally posted by rrileypm View PostThat's my holdup in releasing a RileyROM at the moment. No successful update.zip for stock recovery...and failure to flash with SP Flash Tool.
The readback or download should be started in SPFT before connecting the (switched-off) tablet via USB. MediaTek VCOM drivers need to be installed.
No, you aren't the first to brick this tablet. I unbricked it by holding down volume- and power. The screen that came up was in Chinese, so I had to use trial and error to go through the menus and finally get it to do something. (No Google Translate for Chinese recovery screens, I'm afraid). So, don't ask me exactly which menu item I found to do the work...I couldn't begin to tell you.
While I have made some good MTK ROM's thus far, this one is way different than the others...the files are in different configurations...but I'm getting the nerve to attempt a flash of my test ROM to see if it works with the newest version of the SP Flash Tool. Unless this test flash goes horribly wrong, be looking for a custom ROM for this tablet in the next couple of days. I just want to devote the required time to getting it right.
Thanks for all of the info...your posts are very helpful.Randy
Originally posted by rrileypm View PostHahaha!!!!!! Do you think I can read Bulgarian??????
There are currently 1582 users online. 0 members and 1582 guests.
