So, you need to flash CWM Recovery with the SP Flash Tool. You don't need to be rooted to do that.
Then install the zip file from CWM Recovery.
The stock recovery will block the installation of the zip file.
You can get CWM by downloading my 1.3 ROM. It's in the RileyROM folder. Just use the tool from the ROM kit, uncheck everything except recovery...browse to select the CWM Recovery and flash as "Download Only".
