Wish List for MTK Tablet ROM's
Originally posted by felixstars View PostRandy
Here's that Teclast ROM:
Randy
Randy
Thank u!!!
okey now all the file are generated at this adress http://goo.gl/VjYFDM
Thank u for helping me!!! it's very kind of you!!
Thanks....it may be a few days before I can get to it....I'm working. Maybe tomorrow night. PM me if I forget.Randy
OK, Aldup...here you go.
This ROM is debloated, rooted, init.d and busybox support added.
I haven't made a CWM Recovery for it yet...but if you want I can. The tool you used to dump the ROM can make the CWM for you with the recovery.img and boot.img you dumped.
What you need to do before you flash this ROM is to download MobileUncle from the Play Store. Back up your IMEI number and whatever else it will back up to your external SD. That way you can recover it easily after you flash.
You have a choice of 1, 2, 4, 6, 8, 10 or 12gb user app space (how high you go depends on how much total NAND is installed on the device). You just need to substitute the EBR1 and EBR2 files with the ones labeled with the size you have. In order to change the partition size, you need to flash these EBR files then boot to recovery and do a "wipe cache/factory reset". This will totally erase everything on your phone...so be sure you have a complete backup...especially the IMEI number I mentioned above.
In the ROM kit is a PDF file with flashing instructions.
Download
Enjoy!!!!!
If this works, OK for you...let me know and I will start a new thread for this ROM.
BTW...you're the first member I've seen from Africa....cool!!!!!!!!Randy
Download
Enjoy!!!!!
hey thank u i didn't thought it will be so quick thank u so much !! i'm going to try that right now i'll let you know asap if it's working !!!!
hey!! i have successfully flashed the rom despite the fact that the flash tool was really buggy!! the system is smooth, i have a larger internal storage !!!
just a few issue with playstore there is black background on icons! as u can see!!
So what's next ? Do you plan to port kitkat on this device ?
That would require a working KK kernel, compiled specifically for your device. That would require source code and a developer who actually has the device to test.
Our only hope is that the factory releases a KK firmware for your phone, I'm afraid.Randy
Originally posted by rrileypm View PostThat would require a working KK kernel, compiled specifically for your device. That would require source code and a developer who actually has the device to test.
Thanks for the update.
I will make a new thread for this in the MTK Phones section.Randy
Allwinner-Tablet/Polaris-a70H: 4.2.2/JDQ39/20140530:eng/Test-keys
Not sure what happened to my first writing. But as you can see while I was rooting ,my phone with king root my ROM, I guess got disrupted. This big red word demo is a problem and would like to get it off my screen. Hope I'm in right place. Also my clock is force closing now too. Not sure if that was cause but I assume it was. I use busy box, titanium backup and build properties. I have ROM manager but a little Leary of that program. I think this partition is in the works as far as development from what I've studied. But this site seems to be the closest thing to this getting this type of system straight as far as what I see here.
Hope you can help.
Marc
There are currently 3008 users online. 0 members and 3008 guests.
