Wish List for MTK Tablet ROM's
    If you have a request for one of our developers to create a custom ROM for your device, just make a post in this thread.
    The ground rules are simple.
    We need to know the Brand and Model of your device, and we require a link to the official factory firmware for your device. Some spec information would be nice like NAND Flash capacity, what MTK chip is in the device and the actual screen resolution.
    So, here is the format you should post:
    1. Brand Name
    2. Model Name/Number
    3. Which MTK chip is installed
    4. Link to stock firmware or a ROM dump from your device
    5. Total NAND flash capacity
    6. Screen resolution
    Please post your request in that format, and wait to ask until you have a link to the firmware because we can't possibly have access to every factory firmware on the planet without your help.
    We may need to add some more rules as we go, but this is a start.
    Randy
    Excelvan ET704 , 4.4 kitkat rom would be amazing.It's a 7" 1200x600 resolution phablet (phone tablet) details are below.
    Model number: K7206
    Baseband version: MOLY.WR8.W1315.MD.WG.MP.V1, 2013/12/17 16:33
    Build number: K7206_QSVGA_V10
    Maybe the rom is the same as another oem product?If so maybe i could just flash another rom with kitkat on it already?
    What is the world if you don't explore?
      No problem. It will be tomorrow night before I can get to it. Meantime, if you can find a link to the firmware it would be great.
      I don't want to get started porting ROMs from different devices....toooooooo risky, especially since I don't have the device in hand to test, myself. I hope you can understand that. Android ROMs are very device specific.
      Randy
        Teclast G17S
        I have this one, and it have a lot of chiness apk.
        I need a easy rom, with market.
        Can you recomand a rom for this device? Tanks
        Thanks.
          Sanei G706 Quad Core 3G phone tablet MTK8382
          Sanei G706
          MTK8382 1,3 ghz
          Resolution screen 600x1024
          Baseband MOLY.WR8.W1315.MD.WG.MP.V15.2013/11/01 11:03
          KERNEL 3.4.5 hx03@hx03 #1
          build G706_01_v006_20140423
            The main requirement is a link to factory firmware. We need a minimum of that to get started.
            Randy
              Link to the rom for me is dead. Sanei web is offline now. I can give you only a nandroid backup of base rom without some system apps in chinese.
                That would be good.
                Randy
                  That would be good.
                    OK. I'm on the road...heading home today. I will look at it this weekend.
                    Randy
                      I'm going to need some more files than this. Everything is in .tar files...not the actual system.img...etc.
                      There is an app called MTKDroidTools you can use to make a backup of the whole firmware.
                      You can try it and see if you can get a complete ROM dump for me.
                      Randy
                        Mtkdroid tools not work in my case. Loop after backup scatter for hours and i must disconnect usb cable
                          Want android 4.4 on my Soulycin SMMS5
                          Hello!!
                          I want a custom rom for my Phone Tablet Soulycin SMMS5! It's android MTK6589 phablet with android 4.2 i provided a link for the rom files!!! please help me i really want kikat on my phablet!!!
                          https://drive.google.com/folderview?...DQ&usp=sharing Drive link stock firmeware files.
                          Sorry for my bad english
                            Teclast P89 3G MTK8392 custom ROM
                            Hello
                            It is some days that I got this tablet Teclast P89 mini Retina 3G MTK8392, and it is really a good tab with a great display (iPad mini retina like), with a custom ROM (to remove all useless stuffs) anf Root it will be perfect. Here are some details :
                            Model number: P89 3G 8Cores (D1H8)
                            Baseband version: MOLY.WR8.W1315.MD.WG.MP.V39, 2014/04/12 14:38
                            Build number: V1.04_20140605
                            Screen Resolution : 2048x1536
                            Firmware link :
                            http://dl.vmall.com/c0bovmjn5j
                              Originally posted by Aldup View Post
                              Hello!!
                              I'm afraid there isn't enough here to make a complete ROM. I'm need all of the files from a ROM dump.
                              Randy
