More 610 info. It takes a lot longer to boot. You have to hold the power button for at least 5 seconds. My wife's 620 is closer to two. Booting into recovery also gives you different menus, but i think that has as much to do with the differences between JB and KK.
Wish List for MTK Tablet ROM's
I think what I'd like to see for the 610 is enabling the fast charging, custom boot animation (can that be done in xPosed?), and maybe a few tweaks here and there. I've read that the 610 is not getting KitKat, and for what I use it for, I'm ok with that. If custom ROM's start cropping up for it that lead to KitKat and possibly Lollipop then I may jump on board with that.
Originally posted by trf View PostI think what I'd like to see for the 610 is enabling the fast charging, custom boot animation (can that be done in xPosed?), and maybe a few tweaks here and there. I've read that the 610 is not getting KitKat, and for what I use it for, I'm ok with that. If custom ROM's start cropping up for it that lead to KitKat and possibly Lollipop then I may jump on board with that.
The boot animation is in the system folder and can be changed on any rooted device. There are LOTS of Play Store apps that let you choose a boot animation and swap it for you... some of them even let you choose multiple ones and rotate them so it's different each boot...
Any logo splash screens before the animation are another story... The kernel can have a logo, the boot image can have another logo, and some devices have additional logos in special partitions... none of these can be changed by the average user... changing them requires learning pretty much everything about ROM development for the particular hardware type...
ShaunMTFreaktab Rom Developer
Originally posted by shaunmt View PostInteresting... that is the best description I've heard yet about the RCT6103W46...
Sounds like there are at least 4 versions of the RCA Pro 10 then... I am sure there was a cordless bluetooth keyboard version and corded usb version with a RK3188T...
You're probably correct about more internal differences between the 610 and 620... especially considering they have different charging ports...
What is it with all these chinese manufacturers making tablets with usb only charging and not enabling usb fast charging in the kernels!?!?
ShaunMT
Originally posted by trf View PostSeems you are right on the specs. It came with either the bluetooth or USB keyboard, and the 1.4 quad core chips is RK3188-T. That makes the 610 a rockchip device right? Which would mean the 610 is not an MTK device? Or am I wrong here?
The build.prop file might offer some clues, or an app like cpu-z or cpu identifier should be able to identify the processor.
If you can access factory firmware for it, send me a link and I can do a Rockchip ROM for you...but let's carry on further discussion in the Wish List thread for RK ROM's.
If there's no firmware available (which is typical for RCA products...they don't post firmware on their site for some reason)...you can attempt to provide a ROM dump from your tablet for me.
This is for RK only...but here is a ROM dump method...it works better if the tablet is rooted.
Open a terminal
Type su and enter to get the # prompt.
Then just dump using the DD command in busybox and dump to SDcard.
dd if=/dev/block/mtdblock1 of=/sdcard/kernel.img
dd if=/dev/block/mtdblock8 of=/sdcard/system.img
dd if=/dev/block/mtdblock2 of=/sdcard/boot.img
dd if=/dev/block/mtdblock3 of=/sdcard/recovery.img
Check your MTD blocks for the same number but most have been the same.
Also, each of my RK ROM's includes a ROM dumping tool...which may be a better choice...the instructions are provided. This will allow you to also dump the parameter file, which is another important part I need to make the ROM with.
However you do it...I need:
parameter
kernel.img
boot.img
recovery.img
system.img
If there is a resource.img...I need it too...but that's only for RK3288 devices.Randy
CUBE TALK79 Octa-Core
I'd like to expand my user app space, but I don't know well about the system.
1. Cube
2. Talk 79 Octa Core
3. MTK8392
4. Link to stock firmware(http://www.51cube.com/ch/DownShow.asp?ID=273)
5. 16GB
6. 2048X1536
Please, make custom rom for this model.
I personally don't do them...but maybe another developer would be willing.
So, yes....you can post your request. It may or may not get fulfilled, though.Randy
DigiLand DL1010Q 10.1 MT8127
My full dump is linked in this thread, I can't upload anything.
Hardware : MT8127
Model : DL1010Q
Build number : A1008L_V1.4.2
Build date UTC : 20150112-094502
Android v : 4.4.2
Baseband v: -----
Kernel v : 3.4.67 (lai@lai-To-be-filled-by-O-E-M) (gcc version 4.7 (GCC) ) #3 SMP Wed Jan 14 17:02:06 CST 2015
Uboot build v : -----
LCD Driver IC : 1-crk070b1_18a_017_lvds
Resolution is 1024x600
Calls itself a 16GB tablet but it's a little over 14GB visible through the OS - I can get you a more exact number if you need it.
Can one request ROM for mtk phones too?
Originally posted by rrileypm View PostIf you have a request for one of our developers to create a custom ROM for your device, just make a post in this thread.
The ground rules are simple.
We need to know the Brand and Model of your device, and we require a link to the official factory firmware for your device. Some spec information would be nice like NAND Flash capacity, what MTK chip is in the device and the actual screen resolution.
So, here is the format you should post:
1. Brand Name
2. Model Name/Number
3. Which MTK chip is installed
4. Link to stock firmware or a ROM dump from your device
5. Total NAND flash capacity
6. Screen resolution
Please post your request in that format, and wait to ask until you have a link to the firmware because we can't possibly have access to every factory firmware on the planet without your help.
We may need to add some more rules as we go, but this is a start.
Yes, there's a thread in the MTK Phones forum for phone ROM requests.Randy
1. Brand Name: Teclast
2. Model Name/Number: T98 4G ,model C6R3
3. Which MTK chip is installed: MTK 8752
4. Link to stock firmware or a ROM dump from your device:
http://www.teclast.com/tools/pad/putcode.html. ( entre "C6R3" as model)
5. Total NAND flash capacity:32Gb
6. Screen resolution: 2048x1536
what do u think can i use system.img from your 16gb version?
thanx
In order to benefit from the rooting...you need to use the system.img and boot.img. I really can't see why it wouldn't work if the only difference is in the amount of NAND.
I'm kinda tied up today, but I will download the firmware you linked and put together a new ROM from it.
Remind me in a few days if I haven't posted something.Randy
rca
1. Brand Name
rct6773w22
mt8127
8gb
1024x600Last edited by leetree2001; 07 March 2015, 16:26.
There are currently 2884 users online. 0 members and 2884 guests.
