Wish List for MTK Tablet ROM's
This is the first time I've seen a locked boot partition in an MTK device. I will have to do some research on that. Unfortunately I don't have a Cube tablet to test.Randy
Some functions of MTK Droid Tools are not compatible with 8752 cpu. It gives me that error for other CPU types, too.
Which app are you using to "overwrite" boot.img and recovery.img? Are you using the SPFlashtool?Randy
OK, here are the latest RileyROM versions....again, one post...two ROM's.
iFive_Mini_3GS_RileyROM_1.7 - based on the above firmware
iRulu_X1046_RileyROM_1.0 - based on the above firmware
Enjoy!!!! And please consider a donation....Randy
Originally posted by hidroela View PostTECLAST P98 3G 9.7" Android 4.4 MTK8392 3G Tablet Phone. ID:A4HY
would love an generic kitkat with market and an english boot menu.
MTK8392 chipset
firmware: http://www.mediafire.com/download/35...V1.04-9DEF.rar
I downloaded this firmware from your link....as well as from the official Teclast site. Both files I downloaded show to be corrupted.Randy
Originally posted by rrileypm View PostOK, here are the latest RileyROM versions....again, one post...two ROM's.
Any advice or tips? Thanks again.
In the zip file is a pdf document called "First Time User's Guide". That should point you in the right direction.Randy
Originally posted by rrileypm View PostIn the zip file is a pdf document called "First Time User's Guide". That should point you in the right direction.
If you already have it rooted, is it with SuperSU? That is the reason. I solved the Titanium write issue by using a different superuser. Titanium should work after you flash the ROM.Randy
Originally posted by rrileypm View PostIf you already have it rooted, is it with SuperSU? That is the reason. I solved the Titanium write issue by using a different superuser. Titanium should work after you flash the ROM.
The ROM dump you provided doesn't contain the scatter file. I can make a new system.ext4.img and a new boot.img which will provide most of the custom changes, but I need to have the scatter file to complete the ROM kit for flashing.
Also, whoever did this original firmware stuck the build.prop somewhere else and the symbolic link to it is broken. If you can provide a copy of the original build.prop, I might be able to make a custom ROM....but this one is more difficult than most.Last edited by rrileypm; 19 April 2015, 19:03.Randy
Originally posted by rrileypm View PostThe ROM dump you provided doesn't contain the scatter file. I can make a new system.ext4.img and a new boot.img which will provide most of the custom changes, but I need to have the scatter file to complete the ROM kit for flashing.
Also please do a search on your device for the actual build.prop and send that too.Randy
Originally posted by rrileypm View PostAlso please do a search on your device for the actual build.prop and send that too.
firmware.info was actually present in the larger file I uploaded (full rom dump), I used MTK_rom_studio to convert it to scatter file (found out that PDA net can also do it, but MTK_rom studio doesn't require installation
when I search "build.prop" in Total Commander before I copy it on SD card, it shows in the following way:
build.prop -> /custpack/build.prop
(don't know whether it's relevant to you, as it copies just normally)
Hope this is it. Many thanks!!!
There are currently 1562 users online. 1 members and 1561 guests.
