Wish List for MTK Tablet ROM's
I will have to do some checking. I'm not sure I will be able to do TWRP. Maybe CWM.Randy
Originally posted by rrileypm View PostI will have to do some checking. I'm not sure I will be able to do TWRP. Maybe CWM.
I know I'm just a Little bit beast, cause a couple of weeks ago I flashed my Tablet with the P98 firmware and it booted up with the screen 180º reversed, no táctil response, volumen buttons worked but not power button response I suppose because the generic.kl file configuration. This is the main reason cause I have the hope that perhaps its posible to port the rom with some changes on the configuration and inserting the original Tablet "drivers" inserting firmware and modules files. Forgive for insisting.
Regards!!!
Originally posted by lestillo View PostI know I'm just a Little bit beast, cause a couple of weeks ago I flashed my Tablet with the P98 firmware and it booted up with the screen 180º reversed, no táctil response, volumen buttons worked but not power button response I suppose because the generic.kl file configuration. This is the main reason cause I have the hope that perhaps its posible to port the rom with some changes on the configuration and inserting the original Tablet "drivers" inserting firmware and modules files. Forgive for insisting.
Regards!!!
I used the one I set on my first message and I think is a8h8 firmware. I would like to modd it but I have some problems with the configuration of my pc and I have not too much time...
No, I didn't use any mouse to power off the Tablet, the only thing I did was to press power button during 10 or 20 seconds. I flashed with upgrade command on flashtools aplicattion.
Rgrds.
Originally posted by lestillo View PostI used the one I set on my first message and I think is a8h8 firmware. I would like to modd it but I have some problems with the configuration of my pc and I have not too much time...
Rgrds.
Originally posted by hocuspocus69 View Posteverything is important you said no power button response and in another msg i power off with button this is a learn and teach forum be more sure what you said im joke but its important
I think that perhaps porting is possible but I'm not an expert and also perhaps a cooker could do something.
Sorry for the missunderstanding.
Rgrds.
Hello
For a tablet that does not recognize the touchscreen that i have replaced (buyed from China, with same code on the ribbon cable - VTCP101A56-FPC 1.0). I installed the ROM that i have posted in link and no reaction from touch. The ROM is original. Maybe another ROM can solve the problem.
1. Brand: WINK
2.Model name: Wink Highway 10.1
3.Chip: MT8127 Cortex A7
4.Link to ROM: https://drive.google.com/open?id=0Bx...3lteENlRzhadFE
5. Total NAND flash capacity 8GB
6. Screen resolution 1024x600
Thanks in advance.
Hello!
I really hope you can help me with this, it looks like a refreshed version of the previous one, has got Android 5.1
Tablet Teclast T98 4G MT8735P model number E5C4 http://www.teclast.com/zt/T984G/
Link firmware http://www.teclast.com/tools/pad/showtools.php
Thanks a lot in advance!
There are currently 2443 users online. 0 members and 2443 guests.
