If you have a rooted device, the best way to do a ROM dump is with MTKDroidTools. Zip the entire output and provide a link to it.
Wish List for MTK Tablet ROM's
We actually need the whole ROM dump...which includes EBR files and all three...boot.img, recovery.img and system.img.
If you have a rooted device, the best way to do a ROM dump is with MTKDroidTools. Zip the entire output and provide a link to it.Randy
Manufacturer iball
Model no iball 3gq 7271 ips20
Factory rom link
Mtk false 8382 real mtk 6582
Os kitkat 4.4.2
1gb ram 8gb nand
7 inch tab 1024×600
Link to factory rom
https://www.mediafire.com/folder/4xa...3G_Q7271-IPS20
Factory rom link
Os kitkat 4.4.2
1gb ram 8gb nand
7 inch tab 1024×600
Link to factory rom
Sorry, I've been away for quite some time...but let me download your stock ROM and I will see what I can do with it.Randy
Hi rrileypm!! I need a custom firmware ported from teclast p98 to my teclast t98. The tablets are almost the same with MTK8752 chipset. Same hardware except that my tablet has more sensors.
The firmware link of the p98(lollipop) is: https://mega.nz/#!d9cCABaa!hYQ6rPa4c...N6YdVygbubjOb0
P98 tablet info: http://www.chinistore.com/en/chinese...bluetooth.html
The firmware link of my t98 (kit kat) is: https://mega.co.nz/#!i9Y2FCyY!WNolk1...Y9kbuO9o5rdxQ4
T98 tablet info: http://www.chinistore.com/en/chinese...44-kitkat.html
Regards and thanks in advance.Last edited by lestillo; 23 January 2016, 15:38.
Originally posted by lestillo View PostHi rrileypm!! I need a custom firmware ported from teclast p98 to my teclast t98. The tablets are almost the same with MTK8752 chipset. Same hardware except that my tablet has more sensors.
P98 tablet info: http://www.chinistore.com/en/chinese...44-kitkat.html
Only one way is that if u have kiktak keenel version 3.4.67 then u can port cm12.1 to ur tab if any one has ported to ur soc
Mine is mtk8382 false real mtk 6582 so there r lot of mtk6582 cm12.1 roms around to port tablets r legacy devices so porting is hard and there r no ported tablet roms available to port or use as base so was trying to port mtk 6582 rom to my device if this gets booted up on my mtk 8382 false u can easily port it to ur device
But till now i was unsucessful so asked rriley pm to port
Mee too tryin on my part but stops at boot logo will go on tryin
I dont know if this is helpful but u cant port lolipop to kitkat
U can only have custom or themed rom of ur device of same soc no cm12.1 fr u
Rgrds.
Ok. So my soc on my teclast t98(KitKat) is mtk8752 the same that teclast p98 (lollipop) soc. Also I have to say that mtk8752 is almost the same that mtk6752. Any chance for porting it?
Rgrds.
The only thing you can do is wait for a KK version for your tablet to be released by Teclast. While you state the only difference is the number of sensors....let me tell you...these Chinese factories don't mention that they use many other different components between models. Porting MTK firmware between different devices is way too risky.Randy
There are currently 2448 users online. 0 members and 2448 guests.
