UPDATE July 4th 2012
OK folks..... BETA 1 showed I made a mistake like I did on BETA 1 for the 9G2.
That is NOW fixed. This is now BETA 2 and will possibly be the final release after I get some more testing.
The download link below has been updated to BETA 2 file name.
_____________________________
OK folks.... with the success of the 9G2 2.1 Gingercomb ROM "BETA" test, I am going for broke this time! Here is the 7G2 2.1 BETA TEST ROM.
THIS IS NOT for the 7bG2 or any other 7xxx Arnova tablet! It is ONLY for the 7G2!
This is a full 2.1 with ClockWork recovery, debloated, App Injector, etc! No BETA 2.0 this time. I am pretty confident on this 7G2 ROM based on the 9G2 success. So I just went for broke and made this a BETA 2.1 ROM from start!
I could be all wet here and this doesnt work well..... I hope not. If so I will call it BETA 1. If it does work well, it will be the full release.
__________________________________________________ ___________
PLEASE READ the README.TXT for instructions and what this ROM is about!
You can also read about it on the 10G2 here to learn more about it:
http://www.freaktab.com/showthread.p...ersion-2-1-CWM
REMEMBER! Just like most my ROMs that have major changes to it, ERASE IDB and FLASH THE LOADER! Do this before reporting any problems! You can have screwy things happen if you do NOT erase IDB. Loader is also very important!
Now this is a BETA TEST ROM! I cannot fully test everything! So you are CRASH TEST DUMMY'S
When reporting problems please try to be as detailed as possible! If there is no detail to your problem and the steps you took to make the issue happen, I cannot help much. So to help make this ROM better for everyone, please be a good tester and document the issue as best you can!
Also those that know how to use ADB or pull the logcat file, this will help a lot! So if you know how to do this when testing, please supply a logcat dump.
OK on with the ROM.
Here is the download:
ROM -> Arnova 7G2 - "GingerComb" Finless 2.1 CWM - BETA 2 (205 megs)
Enjoy and happy testing!
