Beelink R89 --RK3288 Cortex-A17 Mali-T7 4Kx2K RGMII HDMI2.0 supported by ODM&developers
OC
What are the frequencies at stock (CPU, GPU and RAM)?
I think more important are the frequencies at GPU and RAM then CPU.
At rk3188 they are using max 798 at GPU and max 800 (also 667 or 720) at RAM (I think 1704 at CPU is good enough if we run into a temperature problem at the SoC)....RK3288 Devices
- Overview BOX (LINK !)
Nice!
Suggestions regarding design:
- Remove text "Home"
- Replace "house", "search" and "wifi" icons with more flat design icons, let them have same colors, maybe white ones
- Replace skin colored active scroller bar with another color (blue?)
Thanks for updateBeelink R89
Pioneer SC-2022
Samsung 55" LED 2012
Previous:
Minix X8-H
Minix X5
Logitech Revue
Great update oman. Nice to hear that things are progressing so well, and the launcher looks nice. I'd tone down the left/right arrows, though. The gradients give them a somewhat cheap look, especially as long as they're cut off.
You probably need something to set the arrows off against a (changeable?) wallpaper, but a 1-2px white(ish) line around the arrows will do the trick just as well.
( When you have some free time, can you confirm that you got all the addresses from the testers? I sent my email right after you asked in this thread, but I can't tell if you really got it. If you gave out some kind of confirmation, I did not get it )
Originally posted by oman View PostWe are trying our best to make some bugs fixed in the last weeks.
Unexpected things always happen..
I hope I can send the samples out in next week...
Update some info:
After increase Cpu freq to 1.9G,and Gpu to 600M, Antutu benchmark can be up to 45k..and running CPU_PrimeBenchmark overnight,it still be running in the morning although very hot,I think the Board quality can hold that frequency...But it's a little difficult to run into OS when cpu in 2.0G ,I didnt try using a fan,maybe it'll be working.
About Dts/dolby,after talking with RK ,they told me that we should get the licence from Dts/dolby,if not they wont support us about this,it's a software things,not hw....If so,I believe our devs can fix that problem,so dont worry..
HDMI2.0 are still on the way...
And we design our new UI:
Originally posted by neojin29 View Posti need Rochchip sources for the 3.10.0 kernel. Are there anyone that can get the sources so i can cook up a kernel for overclocking i have the same board too. here is a link from other site that i am port of there are my pictures and also the dump for ref, i also rooterd my board very easy.http://www.arctablet.com/blog/forum/...ware-20140731/
You are not alone!
Originally posted by oman View PostI have all your contact infos except clarkss12..
thanks again.
clarkss12MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by oman View PostTell something about HDMI2.0,it seems no possible buy one TV supporting HDMI2.0 in China..RK buy one from Japan...And they've already made this worked by tuning software.. Anyone have that kind of TV?
There are currently 3484 users online. 0 members and 3484 guests.
