CS918 - help to find the right Firmware, Kernel vyx_cs918 v2_1
Originally posted by Deivs View PostYou shocked me!!! But thanx for your answer. There is any chip of ram located on pcb? ehh...
My TV Box CS918 was also fake 2GB RAM and also a Mediatek Star Cellphone I bought.
The phone was 2GB RAM(real 1 GB), 1.7Ghz Octa-Core(real 1.3 Ghz Quad), HD Screen(real QHD), luckily the seller gave me a discount after I told him it was fake.
Better to only buy reputable brands and from known companies, instead of from **** or aliexpress.
Geekbuying is going to offer lots of RK3288 TV Boxes very soon.
KK + YouTube = troubles...
I downloaded an KitKat 4.4 FW. This FW is quite good: playback through a network improved and additionally appeared superfluous 1Gb of RAMFunny: when I bought it was specified 1Gb, and now 2Gb. But there is a problem - youtube at video playback shows only black screen! At all so? At the moment I don't know what to do with it
Originally posted by Creaturebis View PostI downloaded an KitKat 4.4 FW. This FW is quite good: playback through a network improved and additionally appeared superfluous 1Gb of RAMFunny: when I bought it was specified 1Gb, and now 2Gb. But there is a problem - youtube at video playback shows only black screen! At all so? At the moment I don't know what to do with it
The manufacturers modify their firmware to make it appear as if there is 2GB of RAM but the actual hardware is still 1GB RAM.
Originally posted by mo123 View PostYou got manufacturer modified 'fake' firmware.
What happens if running apps try to use more than the actual 1GB of ram installed.
Does the system crash ??
Hasn't happened to me yet but the 1GB kernals crash all the time. Ironic.
Originally posted by Deivs View PostHi. Interesting. Which FW? cyxtech_rk31_cs918_8723au_4.4_140802_8G2G.rar ?
Thx mo123 for explanations.
Originally posted by Creaturebis View PostYes it is! If YouTube works for you, share please that version which you downloaded. On an baidu spread some versions with a difference in few days, I download, it seems, the last.
Thx mo123 for explanations.Will test later newest FW from Baidu. IF any tested, how much ram it shows
[cyxtech_rk31_cs918_8723_140814_8G2G_14年hdmi_ic.rar]
Originally posted by Creaturebis View PostWhere it is possible to download this last version? Give me a link pleasecyxtech_rk31_cs918_8723_140814_8G2G_14年hdmi_ic.rar]with cpu working on frequency from 300-to 1400MHz, but I tested 1 gb ram version not 2 gb
FW cyxtech_rk31_cs918V6_8723_140829_4.4_8g2g, Total ram available: 1024MB, scr. resolution 1024x672, CPU clock speed dinamically changing from 312 to 1416MHz. For other options testing...
After testing: youtube.apk working well, WLan, Lan speed is ok, bluetooth working good. I don't see any problems with that firmware. I have cyx_cs918 v_2.3
Yeah! ...Except bluetooth & wlan!Wi-Fi turns on, sees networks, can be connected, but speed is wery-wery-wery small. The same with bluetooth. Probably, there was some new version of a board (in the name of the file it is specified - v6) therefore doesn't work normally!
I build a certain hybrid from two KitKat firmwares: from one kernel and boot, from other image of system. Also I added root. Now everything works normally: youtube and a wireless, but is a pity that there is no dynamic change of CPU frequency...
Excuse me for long silence! Yes, certainly. Check, it seems, this archive: https://yadi.sk/d/_W5MqcRzbL6KH
KitKat 4.4 + Root, CYX CS918.Last edited by Creaturebis; 09 September 2014, 20:45.
Originally posted by Creaturebis View PostExcuse me for long silence! Yes, certainly. Check, it seems, this archive: https://yadi.sk/d/_W5MqcRzbL6KH
There are currently 1656 users online. 1 members and 1655 guests.
