Stock Firmware - Beelink S82/M8 - MXIII 1/2G - Official FW Releases from Beelink - user feedback thread
Does your 113k4 have the misspelt "Dobly", for Dolby in the Advanced Settings?
As a side note could you try installing the AnTuTu Video Benchmark and report back on how... i.e. if the WMV2 & RMVB Formats even playback on your Firmware...
On my 1G MXIII these Formats only render.... More so then actually play on Firmwares >110k4. And only as Black Screens on anything <110k4. i.e. 111~114...k4)
So if These Devices are still being sold (From China...), with the (And I use the term loosely here....), "recent" Firmwares on then, why is it so hard for these Cats to do up a quick Three File Zip File? So to allow anyone who wanted to update... Assuming that these past few Updates are at least good for the 2G owners? (I only have a 1G Device), and I find that the Best Firmwares are either 109k4 or 110k4. When it comes to such things as the amcodec. See my request above!
P.s. Should you be unable to download the AnTuTu Video Benchmark from the PlayStore, I pasted a copy of it on my Google Drive. https://drive.google.com/open?id=0B1...WGc&authuser=0
Originally posted by londonshore View Post
Again the only "difference" is that this Update has Kodi v14.1 on it... And, outside of being able to run some reverse engineering magic on it, was about the only difference I was able to make off of it, over 113k4. That is.Last edited by Ichijoe; 15 April 2015, 14:26.
Originally posted by Ichijoe View Post
Ok this used to be complicated, but since about a Month ago now its gotten a lot simpler.
You just need to download the k200.IMG Version of TWRP, and rename it as recovery.IMG, and then place this on your MicroSD Card. Essentially replacing the recovery.img from the Three File's Zip File. You can also delete the aml_pram File as well since it won't be needed.
All you'd need is the 1xxk4.zip File that you're trying to downgrade to, and the renamed k200.img File (i.e. renamed to recovery.img). This should then boot you into the TWRP Recovery... And yes you WILL NEED A USB MOUSE from this point on! Otherwise it should be as simple as Install -> (Selecting the Location of the *.zip File), -> Selecting the 1xxk4.zip File.
Otherwise you'll need a Windows PC, to install the Amlogic USB Burner Tool, to flash the 1xxk4.IMG Files back to the Box. Which depending on which version of Windows you might be running. May prove more challenging. *cough* Windows 8.x *cough*. The trick here is to deactivate the requirement for ONLY Signed Drivers. I have enough sence to NOT get involved with Windows 8.x. So you'll have to go ask Uncle Google on how that's done.
Given how superior TWRP is to the Stock 3e Rcovery, and how much simpeler it is to deal with I'd highly recommend using this method instead.
Originally posted by JCN77 View Post
Thanks for that, I flashed it and is working great on 108k4. Anyone any ideas where the audio sync issues on everything but XBMC/KODI comes from on later versions?
In attempting to use a TRWP Recovery (I think it was for the S82 IIRC), I just about managed to brick my MXIII, after my first ~20 Minutes with it. Took me the rest of the Day, and well into that night to finally figure out how I could recover it. At which point 108k4 became a distant memory, for me.
As far as I can tell the further back you can go... Oddly enought the better the amcodec gets.... If you scan back a few Pages ~ around the 70'ies (In this thread!), you'll find numerus Posts complaining about bad the 109k4 amcodec is (or was...), over the older 107 & 108 (k4) Firmwares... Which they say just worked!
To answer your other Question... My guess is that these Firmwares are starting to take a real AiO approach, in that the Code gets written Once, and likely then compiled for each Device. before release. Which in turn leaves older devices such as the MXIII without anyone to tighten up the Code. Best example of this is the TCP Large Buffer bug. You have a lage-ish pipe 5MB (50Mbps+) Connection, and still have to deal with lag? Chances are good that this could be corrected by just enabling Large Buffers... Its a known bug that dates as far back as 103k4..... (As I gather this would still be MXII era!), and that bug still lives TO THIS DAY!* So if they utterly refuse to fix something as trivial as this.... Do you really think they'd give a toss about something more complicated like the amcodec? 'cause I don't, and the latest Firmwares prove it. If need be run the AnTuTu Video Benchmark on your 108k4 sometime, and then run it again on anything, above 111k4 and tell me if you can't notice the differences. Notably where the windows Media and Real Video Cooker Parts are either skipped in their entirety, are only shown as a Black Screen. TBF these Bits don't exactly run like Water on 109k4 either but, they do at least render a few... Frames.
*You can read more about that here...
I have the 2G version, wifi is working fine. I only use the box for kodi v15 and Netflix, both of which are now working fine, so I will try and resist all the petit urges I have to keep playing with my setup.
PS I bricked it too trying to install TRWP and 108 was the stock version on GeekBuying
You might want to really go though the 70's of this thread again... if you think 108k4 is that great, you might find... According to those Posters that 107k4 was reportedly somewhat better still. Actually with what I'm seeing it could well be true!, but, I can't go any further back then 109k4 though.
But you'd do well to download the Ookla Speed Test (Google PlayStore), if you haven't and test your Device against it. Both Wi-Fi, and Ethernet. Chances are that the Ethernet is NOT at its full 100Mbps, because the Device (As Stock), is NOT set to use Large TCP Buffers over Ethernet.
And, since I live in a Flat with a lot of other 802.11b/g/n noise its not really possible to use Wi-Fi where I am. So Ethernet is the best option. (Or so I thought), till this explained why it wasn't working. As Ethernet should almost always be faster then Wi-Fi... the exceptions here being a, n and ac MIMO Mode. Something the AP-6181 doesn't do MIMO Mode that is
QUESTION FOR ROM DEVELOPERS.
I have problem with CPU temp since aml change the way how kernel manage virtual CPU temp. Since 105k4 my CPU temp is 5%- 75°C and 95% 80°C and my box runs on 1,2 GHz most of the time with any CPU setting or governor even in standby . Before was real temp 42, 47,51... now is 75,80. To be clear I know why. My CPU is not trrimed shown by dmesg and now kernel manage CPU temp depending on CPU usage, number of the processes ...... This aml thermal control optimization is good for maybe newer CPUs like 802b, 802h or others but I have tronsmart Vega one of the first from preorder . I must say many things are better now but since then mine problem is TEMP.
MY QUESTION IS: which file to change with root explorer from earlier ROM like 104k4 or even 100k4 to have normal CPU temp reading ( normal for my box) and
IS THIS EVEN POSSIBLE. I have found thermal folder and aml_thermal, virtual_ thermal but they have many files in it . THAT'S WHY I ASK SOMEONE WITH MORE EXPERIENCE IN ROM DEVELOPMENT.
I know that you are bussy now with new boxes like pipo x7 , draco ... but if you can please share your knowledge with me. My box is tronsmart vega 2G16G same as beelink s82 currently on 109k4(best ROM ever) with 2 extra fans and bigger aluminum cooler on the CPU + OCZ FREEZE thermal paste . Box is allways cold and it's shows 80°C. Help please.
Well it could either be a Kernel Problem... Seems possible in which case, not only would you need to recompile it again, you'd also have to have the Source Code as well. Possible? perhaps though I haven't been able to find the "Trick" to that yet myself. Or more likely its a defective / misaligned Sensor? That's giving you incorrect readings. If you fire'ed up CPUz (Grab it on the PlayStore if you don't have it!), how many Cores does it report going off? In reality it should only likely be the One. (At stock!), unless you used some tool like KernelToolkit (Also in the PlayStore!), to run all Four Cores at Max at Once. I think I might have my Box setup like that just to try and see if I could get a better score in the AnTuTu Video Benchmark. I also noticed that its now JU-JU-JU-JU--- Jumping after about an, hour or so, and has even had a hard crash. So I think I'm gonna reset that App and get rid of it. Since I find, (Or, found), this Box to be ok without it. Its certainly no better with it, thats for sure.
See this http://freaktab.com/forum/tv-player-...r-to-consumers
Again I know why is everything is like it is but a ask this: I want newer firmware like 109k4 with thermal control from 104k4 because for me that's work great. Is this possible? I want to patch newer ROM with older files I just don't know which files.
With 104k4 my CPU temp reading is normal 39 -54° C 54 on antutu stability test CPU settings max 1992mhz min 408mhz governor interactive.
But so many things are not good on that ROM to get back on it.
Originally posted by watson007 View Posti have a strange problem with my MX III (1 GB) Box. Often it gaves beep sounds through the soundspeaker out. I use the spdif sound output.
How to solve the Problem?
nein Ichijoe, ein Piepen das aus dem Lautsprecher kommt - Störgeräusche. Alle paar Stunden kommt es wieder.
irgendwo habe ich gelesen dass das davon herkommen kann wenn die Geräte schlecht geerdet wurden.... ob es daran liegt?
mein Englisch ist nicht so gut und du kommst ja auch aus Deutschland.
There are currently 4107 users online. 1 members and 4106 guests.
