Stock Firmware - Beelink S82/M8 - MXIII 1/2G - Official FW Releases from Beelink - user feedback thread
Oman can you ask Aml about a fix for ps3 blue tooth issue as believe its driver based issue of why it wont connect??
Edit: Does anyone have a link to remote app for m8 ?Last edited by scooter2014; 27 July 2014, 22:56.Many devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
Originally posted by scooter2014 View PostOman can you ask Aml about a fix for ps3 blue tooth issue as believe its driver based issue of why it wont connect??
Will put it into 108k4,hold onEasy way to catch LOG -> Search 'Syslog' in Google Play,then install it and catch log
Originally posted by gizmomelb View Postit's not out yet, but hopefully VERY soon - also hopefully the source will be available for the new firmware developers.Easy way to catch LOG -> Search 'Syslog' in Google Play,then install it and catch log
Can someone please clarify if this box supports Dolby TrueHD/DTS HD-MA formats?
I had no luck playing movies with lossless audio tracks in XBMC -- it recognizes the HD formats but they're downmixed to DTS/DD 5.1.
There was a review of this exact same model which claimed MBox can decode HD audio tracks. Am I missing something? So how to make it work?
Originally posted by fikhl View PostCan someone please clarify if this box supports Dolby TrueHD/DTS HD-MA formats?
depends on the firmware that you used i know in leolas rom its working in xbmcMany devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
Originally posted by gizmomelb View PostThanks for the upload Oman!
>1.Add 1080P24Hz support
is this auto framerate in Android by any chance? It'll probably be a day or two before I'm able to test this firmware. thank you.
Originally posted by the111 View PostWill the TF update method keep all apps and setting?
Originally posted by clarkss12 View PostJust installed 108k4 from Oman, but wifi would not connect and email would not work. Going back to Finless 1.8.
thanksEasy way to catch LOG -> Search 'Syslog' in Google Play,then install it and catch log
There are currently 4879 users online. 0 members and 4879 guests.
