Stock Firmware - Beelink S82/M8 - MXIII 1/2G - Official FW Releases from Beelink - user feedback thread
Originally posted by Biatsch View PostUse soundabout app and disable usbaudioor exchange audio_policy.conf in etc with rootexplorer with this one https://www.dropbox.com/s/u3npz5domu...io_policy.conf than set filepermission on new file to rw-r--r-- reboot ur box ......... Have fun with ur mele....... Fault is that android uses the audiooutput of ur mele
When I exchange the file, XBMC didn't start. It throws an error and close.
And with the app.... no matter if the USB is ON or OFF, when I put on the Mele dongle,,, the audio goes off inside and outside xbmc. Can you tell me which options must I check in the app and which ones leave unchecked.
Thank U.
AW: Important - Stock Firmware - Beelink S82/M8 - Official FW Releases from Beelink - user feedback thread
Originally posted by Servant7 View PostWhen I exchange the file, XBMC didn't start. It throws an error and close.
Thank U.
Ur box
Originally posted by Biatsch View PostDid u set the rights on file after exchangin ? Its important !!!...... U have to purchase the app set output to hdmi.......
in setup/sound don't appears nothing about sound hardware. Is it normal?
When i put the dongle... No sound at all, no matter what i choose. Can you send me screens of your conf?
Thank u. It's driving me crazy !!!
some feedback...
1. People app is still not syncing contacts - PLEASE FIX!!
2. no ringtones/notification sound files to pickdid you remove them?
Another note about this: in older versions when there was sound files to pick from, everytime i selected one to hear how it sounds in order to pick one, NO SOUND will play. Also while in launcher and settings app, new Notifications DON''T SOUND, but it will sound while using the other apps. PLEASE CHECK IT OUT!
3. mx player response is veeeeeery slow. Please check that too!
4. PS3 bluetooth connection not working
Overall enjoying 108k4 but if you could once and for all permanently fix the bugs mentioned above then i could finally say it was wortth the money and start recommending it.
Oh btw, I have 2 custom keylayouts for 2 remotes (same model different branch) not supported in all the firmwares around that you could add. Here's the link:
Originally posted by Servant7 View PostYes i have changed the permissions with root explorer, but xbmc dont start. When i copy back the original file, xbmc opens right.
Should look like this ........
When u got no sound it seems u didnt set filepermission on audio_policy.conf after inserting..... Causes no sound overall cause file wouldnt be read from android..... Dont forget to reboot .......
http://www.freaktab.com/showthread.p...ll-mini-H7-etc
Were some of these issues in my last Finless ROM or are they new to this ROM?
Pretty sure I fixed calendar and contacts sync in my last ROM?
Originally posted by Finless View PostWere some of these issues in my last Finless ROM or are they new to this ROM?
BobMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by clarkss12 View PostYou fixed the calendar sync, thanks The contacts sync has not worked on any of the roms for my S89H. As a work around, I just created a vcf file from my Google contacts on my computer and import them into the contacts app on my android device.
PS3 BT issue is a driver stack issue. It's a Google 4.3 issue you can search it. I am sure it will get fixed soon as some have fixed it already like CM.
Abdul_PT seems to be working on it and may have already made progress. But please don't bug him about it.
Originally posted by oman View PostThere is no support for Flash Player in Kitkat now.
You can give me the link for live video stream,let me check.
Ok,THX,in next ROM release,I'll merge it.
There flash support in kikat use modfied flash.apk and also dolphin browser its the only browser to support flash with the hacked flash apk.
JustMeBugs are Sons of Glitches!
JustMe
Originally posted by Saris View PostI have tested some h265 video samples in 720p (108k4 firmware).
xmbc - audio only
4k player - audio+video (not very fluent)
mx player pro - audio+video, quite good quality, after cca 5minutes of playback audio sync issue appeared, also MX player response was very slow
Can someone confirm similar issues?
s812/s805/rk3288 can decode very well..
http://www.freaktab.com/showthread.p...ll-mini-H7-etcEasy way to catch LOG -> Search 'Syslog' in Google Play,then install it and catch log
There are currently 2767 users online. 0 members and 2767 guests.
