You have a S89 Elite,right?Do what Magnus33 said,If it can match your needs,why buy another box?
Stock Firmware - Beelink S82/M8 - MXIII 1/2G - Official FW Releases from Beelink - user feedback thread
Originally posted by Veronica View PostAnyone???is the built in decoding for S802 chips (Not 802-B/802-H) true? if so i would like to know how (tech explanation i dont mind). Is iit real hardware decoding or it's software decoding built in?, i mean can i open mxx player or other non xbmc player and get dolby/dts software or hardware decoding? for sure this deserves an explanation isn't it? i'm very curious.
I own a tronsmart vega elite and was looking to purchase a -B or -H box and a 5.1 sound bar or sound system, THAT IS WHY I NEED TO KNOW BEFORE SPEND IN OTHER BOX and as you can see i don't have how to test dolby/dts decoding...
someone properly explain please
I to could not believe it my box only originally decoded ddhd I wanted to send the box back my seller told me there would be an update for dtshd I refused to believe him but it happened 107k4 and up I believe but wasser's 106k4 had dtshd decoding as well.
try the 108k4 rom feels smoother the home screen lag is gone.
My S82B just came today, I installed the latest firmware, it's the best yet, everything works very well,
1 problem I'm having is connecting my PS3 controller via bluetooth,
works fine with the USB cable connected, but it just won't see it on bluetooth,
I'm using the sixaxis controller app, I'm sure I had it connected on bluetooth with the 1.8 finless on an S82.
Could be wrong though, I got a 5 different android boxes kicking around here hard to keep track.
I know for sure it works fine on my rockchip box
Originally posted by Saris View Postis the preinstalled xbmc in 108K4 made by stan? or it's a different version?
anyway... the new version 108K4 rocks
I moved from Finless 1.6 to 108K4 and it's a great step forward (tronsmart s89 elite)!
Thanks for a great ROM!
They took all the updates/fixes and improvements from all the roms here and put it into 108k.
When the guys are done modding it things should be really wild.Mk802IV Neomode 1.9a original rom 720p
Originally posted by oman View PostForget about what other guys said,Just believe what your test result..
You have a S89 Elite,right?Do what Magnus33 said,If it can match your needs,why buy another box?... Chips are same?
About last firmware, i have an issue with screensaver feature.
I activate 4 min delay, and it works OK first time, but next time, box fall in deep sleep (red led).
Thx Oman for nice update.
Last point, a Mx PRO version is in last rom, not a free one
Hi!
Thanks, this ROM is really great. Good performace etc.
I do have a question which is slightly off-topic. But I would like to know if it is possible to setup a Logitech Harmony remote with enabled Pause and Play buttons. I already configured my Harmony and have added the S82 as Tronsmart Vega S89. Thats working just fine. But the Harmony Play and Pause buttons are not working. The remote delivered with the device doesn't have this buttons so this might be the problem.
Has somebody a solution to enable the pause & play buttons on the Harmony?
Thanks,
Stefan
Originally posted by Magnifico View PostIs that question for OTA really intelligent?
I beg to differ.
Who would want a Stock firmware update when one is using a custom firmware with so many fixes and improvements over stock?
Unlike rockchip the guys behind these devices have no problem giving credit to custom makers and including the improvements.
Look at the description.
108K4->
1.Add 1080P24Hz support;
2.Support for NTFS/CIFS; --Offered by wasser
3.Change Input method to Latin,and remote can use;
4.Update Play Store;
5.Support for Mele F10 air-mouse; --Pulled from Bob's FW
6.Support for Xbox/PS3; --Offered by Bob
7.Change method of Root access; --Offered by leolas
8.Add kill-recent-task function; --Offered by daemonium
9.Update xbmc to Gotham 13.1,fix 4k playback and 2160P/720P HDMI display issue; --THX stane
10.Add remote function in Recovery Mode;--THX leolas
11.Adjust MBXLauncher,add Yahoo wether and Clean-Memory function,fix slow animation issue;
12.Fix issue->Power-key of Remote might lead to reboot;
13.Improve small probable of blurred screen.
Which explains why the firmware improves so fast.
I beg to differ.
The advantage will be, if implemented, the ability to update the ROM without loosing installed apps and settings.
Originally posted by the111 View Post...
The advantage will be, if implemented, the ability to update the ROM without loosing installed apps and settings.RK3288 Devices
- Overview BOX (LINK !)
live video stream
I noticed that there some discussions (in wassers ROM thread) about the missing functionality for live video stream (real time stream).
Oman, please can you tell us which version of Flash Player is used in KitKat, is it the original version from google or is it the already modified version like posted in xda developers forum (link but works only with dolphin + ff I guess).
Unfortunately google have removed some APIs so that live streams not working with KitKat (An imp who mean this was done without a hidden agenda)Ainol Aurora II (CyanogenMod 10.1)
Ainol Flame NP 20130916 (CyanogenMod 11 (4.4.4))
Lenovo Yoga 8
Geniatech ATV1200 (UBoot 20130805; MyGica Build 20130927; XBMC Gotham 13.1 RC1)
Tronsmart Vega Standard (Stock 108K4; xbmc-13.2-Gotham-4K-video-2160P)
There are currently 4914 users online. 0 members and 4914 guests.
