Stock Firmware - Beelink S82/M8 - MXIII 1/2G - Official FW Releases from Beelink - user feedback thread
I am using a flymouse with Beelink M8. I found that since 105K4 (or 106...cant remember), after the device go to stand by (red light) for a period, then switch it on again, I cannot use the flymouse. I have to unplug the USB receiver and plug again to get it work. Any idea for this problem ..? Problem still here in 107K4.
Thanks.
Originally posted by kikikaka View PostI am using a flymouse with Beelink M8. I found that since 105K4 (or 106...cant remember), after the device go to stand by (red light) for a period, then switch it on again, I cannot use the flymouse. I have to unplug the USB receiver and plug again to get it work. Any idea for this problem ..? Problem still here in 107K4.
Thanks.
Originally posted by medmed View PostWhy parameters time and date are stored has stopped (power) of the box?
This is a real problem, because it prevents the synchronization of Google play in addition to having to retype each time the date and time.
There is not RTC battery in box.Easy way to catch LOG -> Search 'Syslog' in Google Play,then install it and catch log
What this means is when the box boot and connects to wifi to Ethernet, it gets the time set based on a internet time server.
My box does set it's time every time it boots! So your router is not setup to do that or is blocking the ports to do that.
This is NOT a ROM problem... it's your setup.
J'ai installé la rom Leolas V1.0.0 , et je n'ai plus ce problème de date même après extinction de la box. Donc pour moi c'est bien un problème de rom
Sorry, I do not speak English, translated with Google translate...
I installed the rom Leolas V1.0.0, and I no longer have this problem even after termination date of the box. So for me it is a problem of rom
Video webview issues
The only issue I have is playing video through webview on these devices. When video plays the app crashes. I would love for this to get fixed. I have no issues with rockchip or any other device at all so it's something with these devices. If someone can get that fixed, I know of at least a hundred devices would be sold fairly quick. If not I'll wait for rk3288 devices from tronsmart and minix.
Originally posted by cee773 View PostBuilt in played ddhd and dtshd on the mx player says H/W decoding
The decoding of dts/dolby for S802 feature posted in OP is confusing mostly because users claim it is built in, can someone plase clarify this.
if this is true then there is no need to buy expensier S802B box or S802-H, right? but i don't think that is the case.
S82 box not booting when AC becomes available
Hi Oman,
Is it a hardware limitation that the S82 box has to be explicitly switched on with the power button on the right hand side, instead of simply starting up, when AC becomes available?
I am using a power outlet switch to disconnect the device from the mains and ideally would like to be able to power on the device via the remote control then...
Best Regards,
BOFH
There are currently 2459 users online. 0 members and 2459 guests.
