Stock Firmware - Beelink S82/M8 - MXIII 1/2G - Official FW Releases from Beelink - user feedback thread
Originally posted by Biatsch View Post@oman
is it possiple to not unload drivers for usb or bluetooth in suspend mode so we can power on over bluetooth remote or airmouseremotes..... Bought 2 rii mini i7 can power off and power on within 30sec after poweroff.......
AW: NEW - Firmware - Issues feedback here for S82/Beelink M8|||Official FW Release |||Solution
Originally posted by daniello9 View PostAre you suspending your MELE F10 PRO and replacing them by this device? I wonder why.but i will get into this by time...... Tried a long time to change remote.conf in etc but when you change it it wont recognice must be something written elsewhere.... (ihave an 1200atv remote from my burned device with orig files but it isn workin will try again by time) tried all this cause i heard that the mele is sendind ir signals for poweron/off it isnt recogniced by keytest
Originally posted by Biatsch View PostYeah i got 2 devices and just 1 mele pro ........ I like the design of i7 its really small and cool only problem that i have with this remotes is that airmouse is the whole time active when u use them and touchpad isnt function.... Dont need the full keyboard on a remotebut i will get into this by time...... Tried a long time to change remote.conf in etc but when you change it it wont recognice must be something written elsewhere.... (ihave an 1200atv remote from my burned device with orig files but it isn workin will try again by time)
Half Ethernet Speed compared to My Hiimedia 600A II
After network tests done for both devices on same switch, it wad found that download and upload speed of Beelink M8 was just half of Himedia 600A II, which scored 50Mb/s download and 40Mb/s upload. I suspected that was the reason why my M8 always stuttered when streaming large bluray files. This was improved a little bit when flash to finless roms but still could not match my Himedia 600AII which cost half the price of M8.
Originally posted by Biatsch View PostYeah i got 2 devices and just 1 mele pro ........ I like the design of i7 its really small and cool only problem that i have with this remotes is that airmouse is the whole time active when u use them and touchpad isnt function.... Dont need the full keyboard on a remotebut i will get into this by time...... Tried a long time to change remote.conf in etc but when you change it it wont recognice must be something written elsewhere.... (ihave an 1200atv remote from my burned device with orig files but it isn workin will try again by time) tried all this cause i heard that the mele is sendind ir signals for poweron/off it isnt recogniced by keytest
RK3288 Devices
- Overview BOX (LINK !)
Originally posted by Biatsch View PostMaybe ur right it hasnt....... Someone figured out how disable the pointer in xbmc tried insert a mouse.xml wich worked in win pc but isnt workin on the box mouse control can be switched off in xbmc but cursor remain
What's about the 'switch' button? Maybe also switches the air mouse on/off or only the device?
RK3288 Devices
Originally posted by Biatsch View Post@omanI got a static ip configured... Just for info
Found a bug on 106k4 when u use ethernet and go to standy and than switch it on again after a few minutes ...ethernet speed lags.... U have to restart ethernet then u will get full speed back
Originally posted by Schlash View PostQuick Question,
Is it possible to update firmware with a USB memory stick rather than with a microSD card or USB cable etc.
Best Regards...
Me.
Let me check into deeply.
Originally posted by dinkidonki View Postsame problem here.
aspect ration needs tp be 720p but it wil not let me change it .
it stays in 1920x1080 mode ?
is there a addon or patch that can change it to 720p and keeps it that way.
also i noticed that dts is not alway playing back ( no sound )
any feedback would be cool , also new to this android thingie so dumb it down a bit
Originally posted by Biatsch View PostFound a new bug cec is workin quite well but when u r in suspend u cant wakeup via cecEasy way to catch LOG -> Search 'Syslog' in Google Play,then install it and catch log
Rii mini i7
Originally posted by Biatsch View PostMaybe ur right it hasnt....... Someone figured out how disable the pointer in xbmc tried insert a mouse.xml wich worked in win pc but isnt workin on the box mouse control can be switched off in xbmc but cursor remain.... so i think the fault with this remote is hardwarebased
(airmouse alltime active on move and click)....... for me generic.kl could remain as it is key 142/143 POWER, cause stopping airmouse Cursor is not really needed (deactivating when using other Buttons would be more comfortable)
@Oman
Thanks ur gettin into not unload the drivers
Originally posted by Biatsch View PostSorry quoted myself, the on/off Switch from rii mini is the Switchbutton for the remote !!! key142 and key143 can be deactivated in generic.kl than we see that the mouse Cursor can be stopped with one click and deactivaded with 2 clicks on the remote...like ist written in description....but airmouse will sill be activated on all new actions.... so i think the fault with this remote is hardwarebased
There are currently 4255 users online. 0 members and 4255 guests.
