Stock Firmware - Beelink S82/M8 - MXIII 1/2G - Official FW Releases from Beelink - user feedback thread
How to upgrade FW By TF card:
1.Unzip the zip/rar file,and copy 3 files(105k4.zip,recovery.img,factory_update_param. aml) to TF card Root directory;
2.Plug in the TF card and Power line,then pressing the button in the AV hole,then press power button,then release button in the AV hole.
3.OK,it will be into update process.[/QUOTE]
This does not work for me. I get the picture of the little android man fallen over. Is there a way to be able to navigate the "volume" button to select from this screen? If I am missing something can you please advise!
Hi where is the 105k4.zip for download?
This update is a IMG file. You cannot use SDcard method with it! You have to use AML flash tool.
But please wait. I convert it to sdcard update style.
Originally posted by Finless View PostThis update is a IMG file. You cannot use SDcard method with it! You have to use AML flash tool.
=> Upgrade By TF card: 105k4RK3288 Devices
- Overview BOX (LINK !)
Originally posted by Finless View PostOMG... this release ROCKS!
While working on my custom ROM 1.7, I cannot believe how much faster this is and overall the best ROM yet!
Finless 1.7 is going to ROCK!
Oman, nice work on 105K4 buddy! This is a great improvement!
Beelink ROCKS!
Still wish I could repartition NAND and get more space as it is just not working. I think it is something with the way Android is reporting space.... But I am going to work on that more.
Basically guys /system is 1GB but is only using 1/2 that! Other partitions also can give up some space. Almost another 1GB of space can be recovered. But, I just cant get Android to show it
1.& will probably be released Saturday
if it is maybe you can port it to the square?
Kind regard
Magnus
@Oman
Here's a link to a 1 min sample 'XVID avi' to demonstrate the jerkiness :-
https://www.dropbox.com/s/ds37mfpu5w6q9bj/test.avi
The above video plays super smooth on my Smart TVs and laptop.
Also, yes BBCi fails to show a picture when playing a video, the sound plays fine. I'm in the UK and have no problem with the iplayer on other devices. I assume that you know that iplayer requires a companion 'BBC media player' to be installed before you get the option to play a video? There must be some kind of HDMI detection going which prevents the picture from being displayed...
Thank you for your hard work - I very much appreciate it!Last edited by dave_999; 13 June 2014, 21:20.
I noticed the video resolution is 624*352,why you watch this low resolution videoEasy way to catch LOG -> Search 'Syslog' in Google Play,then install it and catch log
Oman, everything is working great on my Tronsmart Vega S802-H. The only thing missing for me is syncing contacts and calendar with my Google account.
Thanks for all the support you are giving.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
I have some issue after flashing this on S82B device (I have flashed it with Wide Data and Wipe Media options enabled in the update panel).
Using the internal XBMC supplied within the ROM I have like "Interlace" artifacts during playback.
I have checked this on a copy of Avatar movie 1080p very high bitrate:
Code:Complete name : Avatar.2009.Bluray.1080p.DTSMA.x264.mkv Format : Matroska Format version : Version 2 File size : 23.3 GiB Duration : 2h 41mn Overall bit rate mode : Variable Overall bit rate : 20.7 Mbps Encoded date : UTC 2010-04-28 14:35:33 Writing application : mkvmerge v3.3.0 ('Language') built on Mar 24 2010 14:59:24 Writing library : libebml v0.8.0 + libmatroska v0.9.0 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : [email protected] Format settings, CABAC : Yes Format settings, ReFrames : 4 frames Codec ID : V_MPEG4/ISO/AVC Duration : 2h 41mn Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 23.976 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Writing library : x264 core 93 r1538 bd72d46 Encoding settings : cabac=1 / ref=4 / deblock=1:-1:-1 / analyse=0x3:0x113 / me=umh / subme=9 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=64 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=8 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=5 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=1 / wpredb=1 / wpredp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=30 / rc=crf / mbtree=1 / crf=17.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00 Language : English Default : Yes Forced : No
I have re-flashed it twice to confirm using additional finless 1.6 flash in-between to confirm all was working on finless. I suspect this has something to do with permissions for XBMC ?!
I cant seem to get either the SD card install or USB install to work. It seems to be a driver issue. Can anyone tell me where I can get the correct driver for Windows 8.1? It also seemed to think that there was mailware in the install & I did see something to do with the driver called "worldcup" something. It does not look very legitimate. Anyway how can I get this working?
There are currently 2865 users online. 0 members and 2865 guests.
