Stock Firmware - Beelink S82/M8 - MXIII 1/2G - Official FW Releases from Beelink - user feedback thread
    FW Release->
    The latest:
    Compatible with S82/S82B/S82H+Ap6210/Ap6330 and MXIII(1G&2G DDR)+AP6181/AP6210/AP6330--->All IN ONE
    Upgrade by TF card: Download Here(112k4)
    112k4->
    1.Add Flix Universe.apk
    2.Add "Dolby settings" item at Settings
    3.Support BT MAC customization
    4.Fix the TureHD video broadcast problem
    5.Fix the MPEG codec video broadcast problem
    6.Fix Sony PS3 Bluetooth handle and the platform can not establish a Bluetooth connection, connection prompts "Segmentation fault"
    7.Fix BOX sometimes cannot read Ethernet MAC
    8.Fix HDMI sometimes has no image output
    9.Fix sometimes soft shutdown crashing
    111k4->(Based on AML latest official SDK(1114))
    1.Update xbmc (Based on SPMC13.4.0 --Thanks to koying);
    2.Update Skype;
    3.Ethernet MAC (No need to modify Ethernet MAC by tool ,it can be produced by FW automatically and be unique)
    4.Compatible with our R89 IR Remote;
    5.UPdate DLNA&Airplay;
    6.Fix some issues on some streaming APP,such as Hulu,BBC ..
    7.Many fixes on multimedia playing..
    8.Other little tweaks.
    PS:
    1.Some MXIII(2G) version would be without BT option with this FW.
    109k4->
    1.Optimization Power Consumption.
    2.Improve stability issue When auto reboot,auto suspend,Monkey test,AV file continue playing.
    3.Add protocol: UDP ,RTP , MMS ...
    4.Update NAND/EMMC driver.
    5.Fix some Wi-Fi throughput problem.
    6.Support Antutu videobench apk.
    7.Optimization display effect for HDMI.
    8.Support new feature DRM,Playready L1/L3,Widewine.
    9.Add Secure OS.
    10.Visit America websit netflix and youtube smoothly.
    11.Strengthen encoder stability.
    12.Change the Mxplayer to normal version;
    13.Update xbmc to Gotham 13.2,and open some nodes' authority,so you can install any version of xbmc;
    14.Make the physic power-key to be suspend/resume working by short press,and long press (5s) to shutdown;
    15.Remove the Popup notification when xbmc/Mxplayer/... been ran at the first time;
    16. Add an Icon to show/hide Status Bar;
    17.Support Hausbell Mmini i8 and Rii Mini H7 air-mouse;
    18. Make some portrait APPs to be showed to landscape,such as Antutu;
    19.Fix issue:the A/V Async for MPEG2;
    20. Fix issue:it may auto-wakeup when in suspend state;
    21.Fix issue:the usb port may lose efficacy after resume;
    22. Fix issue:no sound for Notification;
    23. Improve some parts of MBXLanucher;
    24.Fix issue:Google Calendar/People cant sync.
    108K4->
    1.Add 1080P24Hz support;
    2.Support for NTFS/CIFS; --Offered by wasser
    3.Change Input method to Latin,and remote can use;
    4.Update Play Store;
    5.Support for Mele F10 air-mouse; --Pulled from Bob's FW
    6.Support for Xbox/PS3; --Offered by Bob
    7.Change method of Root access; --Offered by leolas
    8.Add kill-recent-task function; --Offered by daemonium
    9.Update xbmc to Gotham 13.1,fix 4k playback and 2160P/720P HDMI display issue; --THX stane
    10.Add remote function in Recovery Mode;--THX leolas
    11.Adjust MBXLauncher,add Yahoo wether and Clean-Memory function,fix slow animation issue;
    12.Fix issue->Power-key of Remote might lead to reboot;
    13.Improve small probable of blurred screen.
    107k4->
    1.Add for CPBLTV live stream;
    2.Decoding Dts/Dolby for S802;
    3.Add suspend and Power-off function by Remote or power button from Status Bar;
    4.Add root access permission.
    106k4->
    1.Enhance system stability;
    2.It can flash Ethernet MAC;
    3.Enhance the power of 4k video decoding;
    4.Fix issue of 1080i video playing.
    105k4->
    1.Fix some LiveTV apk can't be ok;
    2.Optimize Thermal control;
    3.Optimize HDMI/AV;
    4.Optimeze Launcher/Settings,use only 1080P UI;
    5.Fix video burning test fail;
    6.Support secure OS function;
    7.Update NAND driver;
    8.Support APK installation to external SD.
    103k4->
    1.Better xbmc for playing 4k video;
    2.6210_8G compatible with 6330_16G,to be the same FW;
    3.Add PPPoE;
    4.Adjust thermal control,Special for Antutu;
    5.Adjust HDMI signal to more TV compatible;
    102k4->
    1.Better xbmc,no async between audio and video ;
    2.Fix 5G wifi compatibility;
    3.Better for Antutu benchmark;
    4.S802/S802B/S802H are all compatible;
    5.Other little tweaking.
    TOOLs:
    Update tools by USB:
    USB_Burning_Tool_v2.0.4_x86 --> support win8
    How to upgrade FW By TF card:
    1.Unzip the zip/rar file,and copy 3 files(105k4.zip,recovery.img,factory_update_param. aml) to TF card Root directory;
    2.Plug in the TF card and Power line,then pressing the button in the AV hole,then press power button,then release button in the AV hole.
    3.OK,it will be into update process.
    Easy way to catch LOG -> Search 'Syslog' in Google Play,then install it and catch log
    Multimedia->
    1.Support for LiveTV apks:
    Ohozaa TV --ok
    Sport TV --ok
    BBC iplayer
    Netflix
    Youtube
    FloowDroid
    2.How to support 1080P 24Hz:
    Install the Setting APK:
    MboxSetting
      XBMC->
      The latest Gothom 13.1 release version,can be used on s802 platform:
      Download Here:xbmc-13.1-Gotham-armeabi-v7a-oman
      xbmc-13.1-Gotham-4K-video-2160P-output->
      based on xbmc-13.1-Gotham-armeabi-v7a
      1.Decode 4K video;
      2.Fix playing video 1/4 issue when HDMI 2160P output;
      Download Here:xbmc-13.1-Gotham-4K-video-2160P-output
        WIFI/Ethernet->
        How to change the Ethernet MAC:
        1.Download Flash_MAC_tool;
        2.Copy license/ to C:\Program Files (x86)\Amlogic\USB_Burning_Tool (For instance)
        3.Open USB_Burning_Tool,load the key_523.img,and the same as below:
        4.Click 'start'
          Peripherals support->
            Others1->
            How to sign APKS for s802:
            1.Download these tools: sign_apks
            2.
            run in windows cmd (JDK enviroment must be preinstalled)-->
            java -jar signapk.jar platform.x509.pem platform.pk8 input.apk output.apk
            Release Source Code:
            1. The launcher(MboxLauncher):
            https://github.com/oman007/MboxLauncher2
              Known Issues->
              1.Force landscape mode;
              2.Upgrade MxPlayer permanently..
              3.Jerky playback for Xvid AVi;
              4.Youtube,iPlayer playback issue;
              5.1080P 24Hz;
              6.Ethernec MAC flash; --106k4 fixed
              7.1080P to 720P switch problem;
              8.Root; --107k4 fixed ,Add su into system/xbin and a daemon for it
              9.F10pro /rii mini i7 Layout,and suspend function;
              10.xbox and ps3;
              11.Power-off function; --107k4 fixed
              12.Status bar. --107k4 fixed
              13.Ethernet speed downgrade after suspend;
              14.upgrade using usb stick;
              15.CEC suspend function;
              16.Sync playback to display;
                Originally posted by oman View Post
                Others2->
                signing apk works for me Oman
                JustMe
                Bugs are Sons of Glitches!
                JustMe
                  FW Release->
                  105k4->
                  Hi oman,
                  is the cpu managemant better than the version at the tronsmart 104k4?
                  Greetings
                  EDIT:
                  only an idea, but would you like to pack your download e.g. as .rar instead of using the much bigger original .img ?
                  RK3288 Devices
                  - Overview BOX (LINK !)
                    Fantastic Oman! Any chance of a flashable .Zip?
                      Re: Issues feedback here for S82/Beelink M8|||Official FW Release |||Solution
                      Great thread, gone bookmark it
                      Tapatalked
                      if [ $up.post.type = $type.two.lazy.to_use_google ] || [ $up.post.type = $type.silly_question ];
                      then mv $user.contact.up.post /.trash; set response($response.type = ignore);
                      $user.up.post.ignore_in_future = true; fi;
                        Nice to see a new rom! Thx a lot Oman!
                        Few questions & issues:
                        - How upgrade permanently system APK MX ? because impossible to keep new version after reboot 1.74 version goes back.
                        - There is a way to choose app to launch with your status bar button (stock explorer) ?
                        - Antutu still freeze my box....
                        - It's possible to force landscape mode in stock ? (i know app to do this).
                        Regards,
                        rOol
                          Originally posted by no_spam_for_me View Post
                          EDIT:
                          I will put it on our server and compress it. Will also do a ZIP format.
                            THX
                            RK3288 Devices
                              Ty finless and oman i will tested
