Stock Firmware - Beelink S82/M8 - MXIII 1/2G - Official FW Releases from Beelink - user feedback thread
Originally posted by Ichijoe View Post(Again you can find the source to the above here: http://www.minixforum.com/threads/ne...8.1449/page-24)
As to what good these Settings do I don't know, as my DTS Decoder always chokes at that point in the Antutu Video Benchmark. Other DTS (DVD Grade DTS) seems to play back fine under the 4k Player, and XBMC. Perhaps the DTS in the Vid Test is more like DTS-HD, or something? Which would explain why its not working here.
Originally posted by dlangejc View PostIt's cause we're cheap man ... Told u 😉
If netfliks or the like is important i can always use my wd smp or get a cromestick.Mk802IV Neomode 1.9a original rom 720p
Stock Firmware - Beelink S82/M8 - MXIII 1/2G - Official FW Releases from Beel...
Originally posted by Magnus33 View PostI don't really use mine for that stuff anyway and stick to streaming local content for the most part so it doesn't bother me.
For a mini Android pc, it works well downloading etc.
Originally posted by dlangejc View PostJust kidding, I also use other devices, depends on the need.
I can see why some are moving away from android though since its simpler in some ways to get these services working on windows or linux.Mk802IV Neomode 1.9a original rom 720p
M8 HDMI Audio routed to new remote
Greetings Gentlemen,
When I plug in the usb wireless adapter for my new remote the audio which is set in the settings to HDMI stops. From what I have been able to find out the audio_policy.conf needs to be modified but I do not know how to do this. Can someone please help me?
Best Regards,
Best Regards,
Originally posted by rompom View PostI mean kitkat is not for TV boxes.I think Android 4.2.2 is perfekt.Kitkat need to much ram.Is it possible flashing Android 4.2.2 for beelink m8 ?
4.2.2 was still more primaly for the phones and it wasn't tell later development in it and kitkat that it branched over to other form factors like tablets and tv boxes.
Lollipop was developed with the idea that its more then just for phones so hopefully it doesn't have some of the issues we had with kitkat.Mk802IV Neomode 1.9a original rom 720p
Originally posted by bajann View PostI hope u dont use minix keyboard
# usb {
# outputs {
# usb_accessory {
# sampling_rates 44100
# channel_masks AUDIO_CHANNEL_OUT_STEREO
# formats AUDIO_FORMAT_PCM_16_BIT
# devices AUDIO_DEVICE_OUT_USB_ACCESSORY
# usb_device {
# devices AUDIO_DEVICE_OUT_USB_DEVICE
# inputs {
# usb_device {
# sampling_rates 8000|11025|16000|22050|32000|44100|48000
# channel_masks AUDIO_CHANNEL_IN_MONO
# devices AUDIO_DEVICE_IN_USB_DEVICE
Later I will try removing the # from the inputs section which will hopefully let
me use the Minix microphone in Skype.
Just a thought, could the firmware be modified to include an option in settings that would allow you to select whether USB Audio in or out is enabled or not? Even if a reboot was required it would be better than having to edit .conf files.
Best wishes to all!
There are currently 1834 users online. 0 members and 1834 guests.
