Stock Firmware - Beelink S82/M8 - MXIII 1/2G - Official FW Releases from Beelink - user feedback thread
Originally posted by Mywaruk View PostHow did you go about it? iv tried that and couldnt get a connection at all.
In your router you will need to fix the IP of the Beelink. If you are using DCHP this can be done by reserving an IP for the Mac address of the Beelink.
Hope this helps
Originally posted by vermillion View PostSet the IP you want then enter the subnet mask, then the DNS and Gateway (you can find this in your Network and sharing centre\local area connection status\details, on your PC )
Hope this helps
Originally posted by Joker2010 View PostHi,
there a lots of setup switches, most of them self describing, some not.
Is there any user guide describing the setup switches, e.g. for the DTS setup?
thanks
joker
Downmix:
lo/Ro = Stereo
Lt/Rt = Dolby Pro Logic Matrix
DRC: (Dynamic Range Control) a.k.a. The Midnight Mode
It should help keep the Volume at roughly at the same level
Dial norm control:
Meta Data that tells the decoder about dialog level. For DTS tracks default is -31 dBFS (Average Reference Level - 30 dB below 0 dBFS (105 dB peak level) = 75 dB). If it is -31, decoder doesn't have to make any adjustments to the level.
(Yes I copied that line word for word, and no even I'm confused as to what this Setting actually does!)
TranscodeSet 0,1,2
This is a brief explanation of the settings. How useful are these settings for folks who primarily use XBMC and HDMI/SPDIF passthrough and without LPCM support, only Amlogic engineers can answer. It is beyond my comprehension. That said, it is a nice feature set that you can see only in some high-end Blu-ray players.
(Again you can find the source to the above here: http://www.minixforum.com/threads/ne...8.1449/page-24)
As to what good these Settings do I don't know, as my DTS Decoder always chokes at that point in the Antutu Video Benchmark. Other DTS (DVD Grade DTS) seems to play back fine under the 4k Player, and XBMC. Perhaps the DTS in the Vid Test is more like DTS-HD, or something? Which would explain why its not working here.
To me
8.Fix HDMI sometimes has no image output
9.Fix sometimes soft shutdown crashing
And the no image output from HDMI well... my TV says that its not a correct resolution
I have to change the source from HDMI to TV and then back again to HDMI to see something
Originally posted by hereje View Postare not fixed with this 112k4 update, sometimes (very few times) I can't turn on my Vega S89 after I suspend it. I press the power button on the remote, the led changes from red to blue, but no picture, no interaction, and I have to press the power button on the device for 5 seconds to turn it off
And all the .avi Xvids are starting with a 1-1,5 sec black screen (audio is on) in SPMC.
(after 1st reboot .avi-s starting good, but after 2 sec, there's a little black screen, the video continues)
There's a new bug. Starting a new video and hdmi signal disconnects immediately. Had to switch the AV receiver's input to another, and back to the S82's.
HDMI connection is at 1080p 24Hz.Last edited by eM82; 24 January 2015, 22:17.
can someone help please
im trying to update to this latest version the one i have om my mx 3 2gb is 110
so i have the 3 files on my sd card
im in android system recovery
the options i have are
boot system now
aply update from adb
aply update from ext
apply update from cache
date /factory reset
cache partition
i click apply from ext
then i have
update from sdcard
update from udisk
i select update from sdcard and get this
mount /dev/block/mmcblk0pl on /sdcard failed invalid argument now try to read only mount ag
ok i dont know what ive done but i put twrp on sd card i flashed that but i couldnd find it anywhere in apps so i put the firmware files back on sdcard and reset box and it just started loading new firmware so now new firmware is on hope it runs ok ,
how do i access twrp it said it installed ?
@oman thanks for another great Firmware HDMI Problem with faulty colors after reboot seems fixed(Samsung TV)
Rest for me works like butter i love xbmc. FrequencyswitcherCodecs are runnin good since 111k4.......
Just a small question are lags in audio and Video playback fixed in rk3288 r89 device and is hevc x265 and vp9 ready to roll...... Want to upgrade my media system of 2 s82b devices in future with r89 devices to get Hardware hevc
cpu temp
Did anyone notice that since 111k4 CPU temp is 75 or 80 ° C most of the time, or this is only in "my" case. I have one from the first Vega s89 16G from preeorder. When most of the owners had high temp problems my was OK, because of bigger cooler compered to other user who posted pictures. Mine is factory, that's why I say FIRST BOXES FROM PREEORDER. Same with 111k4, 112k4 and finless 2.1. I know that CPU t is fake and that the kernel regulates the CPU but in this case 90% of time CPU is runing at 1200 MHz. I tried finless with different cpu patches same t° with all. And did you notice since 111 k4 when you install fresh rom until restart min cpu speed is limited on 408 MHz. I feel like after rebot rom change CPU setting. For me ROMs are great and improved but I feel slowdowns in games because of just 1200 MHz max.
I make small test. On the top of open box, I have put 12cm chassis fan and under the box laptop stand with two fans. Box was cold and cooler was cold but in idle temp was still 80° C. My friend have beelink s82 and he sales this boxes here in Serbia ( he put newest ROM in every box), same thing on 7 different boxes. On the touch box is slightly warm but temp is 80.Temp is measured with cpu temp apk I have tried others and every apk shows same temp. Oman, finless do you know something about that?
Controller Support (Xbox 360 Wireless)
Hi Guys,
I'm new to this thread and hopefully someone can help me out here
Firstly I'm on the latest firmware build 112k4
I use my Xbox360 wireless receiver and my controller works fine for the most part. Most games the controller reads all the buttons fine. But some games that support the controller don't read properly.
To be honest something weird happens. One game in particular doesn't read the controller but if I unplug the receiver and then re-plug it in (back and forth a couple of times), it works for the game. Its very odd. I have also notices that some games detect 2 game pad controller inputs, when nothing is actually plugged into the usb or with Bluetooth off.
Has anybody had any success with the Xbox 360 wireless dongle. Do I need to use a bluetooth controller or get a ps3 controller?
P.S. I have tried changing the .Vendor_045e_Product_0291 file as I read on another forum but that didn't do anything.
There are currently 3849 users online. 0 members and 3849 guests.
