A found a aplha version of messenger running all the time spikeing the cpu in mine.
Stock Firmware - Beelink S82/M8 - MXIII 1/2G - Official FW Releases from Beelink - user feedback thread
Originally posted by Magnus33 View PostCould be something as simple as a app constantly running in the background.
Could someone please install cputemp.apk from playstore and see cpu temp. On 109k4 and 110k4 everything is ok cpu temp is 60-65 with cpu settings min 408 max 1992 mhz governor interactive. Now 5 min after powering on 80, I notice also stutering in kodi and youtube after 30min.
This is not good.
there are problems with various DRM online videoservices since version 108k4 - just sound, no video. Please, is possible to repair this bug? If you want to try it, I can send you an app which worked in 108k4 and does not in higher versions.
Inbetween - is there possible to download the 108k4 version (SD install) somewhere? There is link only to 112k4.
Thank you,
Tomas
Originally posted by ivanrandjelovic View PostNope. No background process. Cpu usage is 2-3%. This is quad core, apk must be big like some game or cpu eater like zip decompressor.
This is not good.
Thank you,
Tomas
They are drm video services which means the makers built in protection to not run on unauthorized devices.
Doesn't matter what you download the apps for these services have been constantly updated so as not to work unless otherwise stated.
It's not a bug its what the makers of those services wanted.Mk802IV Neomode 1.9a original rom 720p
4K output screen flickers and blacks out
I have the same problem with my Samsung UHD tv. With all the 4K output modes ,the screen flickers and blacks out.
I bought this box because it is supposed to support 4K resolution
Originally posted by Rieuwert View PostThanks
I did however manage to get Finless on it somehow. It was a long and weird road though:
1: for some reason the contents of my external SD card do show up in the booted software but not in recovery mode..
2: I must have pricked the reset button once too many because the toothpick method stopped working after a couple of successes
3: So I installed a reboot-app
4: Copied the Finless-Rom zip to the internal SD card
5: I left the external SD-card in the card slot as well. On it the Finless ROM and the TWRP.img I had taken from the Zipfile and renamed recovery.img
6: rebooted in recovery using the app
7: for some reason it rebooted into TWRP recovery(step 5?)
8: Contents of external SD card not visible but upon going to the internal SD-card, I was able to find and successfully install Finless.
What a mess, but now it works.However, the reason for doing all this was a problem that still persists.
When I go to settings - display - HDMI output mode setting and change to any 4K output, my screen flickers, blinks, blacks out etc. I have an LG UHD TV and have tried all 4 HDMI ports but all give the same result. On the side of the HDMI ports on my TV it says: 4K@60Hz. So does anyone recognize this issue?
Originally posted by kikikaka View PostI have same problem with 111k4. Actually it is switched on (with blue LED), but no video signal, so u think u cannot turn on again and need to reset.. If you blindly press the IR remote power buttons, you still can suspend it again..
Upgraded to 112k4 for a few days , seems ok ..
I guess this is fixed...?
8.Fix HDMI sometimes has no image output
i have 3 boxes here s82 with no video and 2 are revised s83 boards with the hdmi problem fixed, still no video.
thanks for explanation - but the same APP version (binary the same version) works on 108k4 and does not work on any higher version of firmware. This is not a bug???
Tomas.
Originally posted by tomas_em View PostHi Magnus,
thanks for explanation - but the same APP version (binary the same version) worked on 108k4 and does not work on any higher version of firmware. This is not a bug???
Tomas.
The Android mini PCs either don't play the services at all or only play in SD or don't play audio or have some other issue that means the box won't be used for the service. Fixes are usually temporary, spoofing is one method that works some, but usually not for long. A box or two might have slipped through the cracks, people are using them quietly without being shutdown but I don't know of any.
There are currently 2715 users online. 0 members and 2715 guests.
