Stock Firmware - Beelink S82/M8 - MXIII 1/2G - Official FW Releases from Beelink - user feedback thread
    109k4 has wake up issues if left off for 10mins or so like stanes enybox rls even though this kernel is 3.10.33 and not 3.10.53
    JustMe
    Bugs are Sons of Glitches!
    JustMe
      Originally posted by southpole View Post
      I fixed 4 of the S89-H boxes like on post #28.
      southpole
      OK Thanks I'll try that route first :-)
        TWRP space issue?
        In post 25 Finless said “I think it is something with the way Android is reporting space…” when talking about repartioning NAND etc.
        Well I have a weird space issue on 109k4.
        I have used TWRP (latest) to make a backup of my S82B that is working flawlessly & I get the TWRP error below stating that my DATA is 3,371,550,943,012Mb! I cannot restore / backup anything now Is this a TWRP issue or a firmware issue? I have already bricked my MX2 running TWRP & am worried that I have now screwed up my brand new S82b!!
        Is this connected? I have reported this to the TWRP dev here on Freaktab.
        Live as if you were to die tomorrow. Learn as if you were to live forever
          Video playback issue causing the video and sound to go out of sync.
          Primly it seems to be with xvids.
          Mk802IV Neomode 1.9a original rom 720p
            Amlogic team tested amcodec (and amffmpeg) which apparently causing stuttering and desync-ing of xvid-s and their answer is:
            "The problem is probably caused by the system settings which are not properly set. In other word, if your receive the box with the firmware which has no XBMC related settings, you’d better send a request to the vendor to see if they can help."
            I'm affraid it's not the right answer... What do you think?
              Anyone has remote working on 109k4 ?
                I'm afraid it's not the right answer... What do you think?
                Don't know what they tested but they didn't get it correct.
                In 1.8 there no stutter. and yet in 1.9 there is.
                Setting haven't changed between the two so its a no brainier where the problem is.
                It happens in xmbc and also plex which defaults to the on board system for playing local files.
                Either they broke playback or bandwidth which would also possibly cause a out of sync issue.
                Plex being a aim and play client with very minimal setting it can be ruled out as being setup wrong.
                Update:
                With further tersting its more then obvious that this is a completely related to the firmware .
                Any app that depends on the direct play of the firmware shows the stuttering and dync issue clearly.
                Simply going back to 1.8 removes the issue and playback is normal which would not happen if this was a settings issue.
                This also includes mkv files and mp4 videos
                  Hi guys. I am new to this world of tv boxes. I just bought a MXIII. Is this beelink m8 the same as MXIII? Should I flash/install the latest firmware found in the first page? Thanks!
                    MXIII 2GB can use this firmware
                      Guys i uodated to this firmware and lost the remote function ... It could be just me .. But unless u have a keyboard handy id suggest u stay put
                        Remote is working perfectly.
                          Likewise.
                          Bad batteries or dead remote?
                            None .. no idea .. oh screw it ... i ishe the flymouse
                            Sent from my GT-I9505 using Tapatalk
                              JustMe
                              no problems here, i leave it all night in suspend mode and wakes fine when needed all from my hausbell remote control. Since 109k4 was first released so far so good
                                Update:
                                no problems here,, yesterday watched 2 movies, all fine. Though i have a 3tb hdd with my media plugged in directly to the box, don't know your setup and i have all 3 codecs checked using XBMC provided in the firmware.
                                109k4 is better
