Stock Firmware - Beelink S82/M8 - MXIII 1/2G - Official FW Releases from Beelink - user feedback thread
Re: Important - Stock Firmware - Beelink S82/M8 - Official FW Releases from Beelink - user feedback thread
Originally posted by Magnus33 View Posttomorrow cant wait to test it out if bell tv app works ill be in heaven lol
Originally posted by Veronica View Posti wanted to do that long time ago but someone mentioned it wasnt stable, things were crashing. How is the stability in 109k4? did you reboot after the change?
Originally posted by londonshore View PostReally thats great newsill be doing this rom asap can I use this rom on my mx3 ?
Minix Neo X7 - Wasser 1.0.4 OC'd - Kodi-helix with passthrough
Beelink M8B - Wasser 1.0.3 - Kodi-helix alpha 2 + SPMC
Originally posted by ant View PostYeah you need to reboot but it's all done automatically after that. TBH no crashing on apps I use and no effect on stability. After you launch an app the second time round will be faster.
If it's 2gb version your good to go. If it's the 1gb don't think so?
Originally posted by londonshore View PostCan anyone check if the bell tv app in playstore opens ?using 109 please and thanks
Originally posted by clarkss12 View PostIf it is the mobile bell app from the play store, then yes. It opens and ask for user name and password. This is using my S89 running the update from yesterday.
Originally posted by ant View PostYeah you need to reboot but it's all done automatically after selecting ART. TBH I've had no crashing on apps I use and no effect on stability. After you launch an app the second time round will be faster.
The only changes i've done is spoofing as a nexus 10 and flashed a cpu fix from several posts ago.
Originally posted by Veronica View Postok i tried ART but after reboot it bootlooped on me. I force reboot again and same thing. i had to run a command on twrp>advanced>terminal console to fix it.
I run ART on my minix x7 - S5 samsung - M8B without problems
Also I'm using my own rom based on 109k4 so I ripped out the app's I don't want included (like bob does) so maybe one of them is causing the bootloop. I'd hazard a guess on the backup/update.apk and the ota.akp.
Need sleep now its 4 am!Minix Neo X7 - Wasser 1.0.4 OC'd - Kodi-helix with passthrough
Originally posted by racky29 View PostIs this 109k4 ok for s82b.
netxeon s83 v2.1 board roundbox
Cos I just flashed it and got it stuck on googleTV screen
Tried a couple of times
Had to go back to 108k4
Also tried flashing 109 kernel boot.img only on 108k4. And got a soft brick too.
"Official XBMC wont work due to permissions! I will fix that in my ROM. In the ENY forum I made a patcher and it proved to fix it.
I will upload the stock ROM and make it wipe for everyone. Stay tuned. But I will not make a new post for it until we see an "official" 109 release from Oman. I will post the ZIP here.
Originally posted by racky29 View PostNice bob.
Also can someone point me to a thread how to edit the Aml script. I remember reading somewhere you can't just edit and save as normal it breaks the signature
Am I right about that. Is there some info on this somewhere.
FYI you will need java installed in windows which can be a pain.
Updated 109k4 ZIP format ROM
OK here is the updated 109K4 flashable ZIP format ROM.
1) I removed the assertion check at the front of the script so this will install on any S802 device. It will not check what version you have installed already. So you know an assertion check usually checks the device model and the version currently installed. Again this is removed now.
2) I format data in the script so if you do not have the factory_update_param.aml on sdcard (which does the wiping if you use it right) it will still wipe the device.
No other changes
DO NOT DOWNLOAD THIS AND PUT THIS ZIP ON SDCARD!
Unzip this download and you will have the package in a folder called 109k4_stock_rom_prerelease.
In it is the files needed and instructions explaining several ways in which to flash this ROM.
ROM -> Tronsmart S89/S89H & Beelink S82/S82H/M8 - 109K4 Stock ROM Pre-release (401 megs)
Note: I will wait until Oman says this is "official" or releases an "official" 109K4 ROM before I make a Finless 2.0 ROM from it. So please don't ask until then.
There are currently 3588 users online. 0 members and 3588 guests.
