Next on the list to try is CIFS manager (have used it before but to open the files not copy them)
Stock Firmware - Beelink S82/M8 - MXIII 1/2G - Official FW Releases from Beelink - user feedback thread
Mounting points names.
Well, I will quote myself
Originally posted by Pecus View Post
Generally it's a very good TV BOX but has some small, annoying bugs.
After correcting these little things can be the best android (XBMC) media center
2. Names of mounting points of external USB devices are always sda1, sda2, .... regardless of the real partition names.
I currently have 3 hard drives connected through a hub to my PopcornHour (Drives formatted in NTFS partition named "films", "series", "concerts".), and PopcornHour sees them as a resource named "films", "series", "concerts".
I tested it in amlinux - is just as well.
In MXIII Android TV Box these discs appear to be "sda1", "sda2", "sda3", but after the power is turned off and back on again, prev "sda1" is now "sda2", or "sda3", depending on the speed of activation of the disks.
And if you create a media library in XBMC based on the drive name (can not be otherwise?), Suddenly the whole library sucks.
It's not a big problem if you are using MXII only as a simple player. You know, you connect a USB stick and play the movie. But if you use XBMC in library mode, sorry it did not work well.
This is the biggest problem for me. It contradicts the idea of building a media center based on XBMC installed on this item.
And.... what about passthrough DTS HD and Dolby True HD?
You know such an application?
Originally posted by Pecus View PostWell, I will quote myself
Maybe it can be done by installing an application.
I had the same problem as you, when I tried to load a movie in xbmc after I restarted the box. With this application, I'm happy now.
Webview and videos
As an app developer for a digital signage company, I ran into something that was very interesting. I use webview in my app and with video the app always crashed. Now at first i didn't know but now i do. I had to add this permission in the app to get it to work.
<uses-permissionandroid:name="android.permission.WAKE_LOCK"/>
Whats odd is no other device had this issue without it but for some reason amlogic had to have it when running video with webview. This could be the cause to some apps crashing when video is played because their permissions dont include this permission. I dont know if its a bug but could fix a lot of apps.
Re: Important - Stock Firmware - Beelink S82/M8 - Official FW Releases from Beelink - user feedback thread
Originally posted by woneal View PostAs an app developer for a digital signage company, I ran into something that was very interesting. I use webview in my app and with video the app always crashed. Now at first i didn't know but now i do. I had to add this permission in the app to get it to work.
Webview with video
Originally posted by londonshore View PostI hope this works for bell tv app ... wanna test it for me lol
Originally posted by Veronica View PostWell this rom comes rooted, unless you are asking for another non rooted device. If those hdd's contain you media and you use XBMC then you can re-locate those drives somewhere else and use XBMC to add smb, nfs or whatever you use as new source, that won't require root i think.
As for relocating the hard drives and sharing their content from a PC, well here's the thing:
In Windows 7 (not sure about Win 8 as I haven't tested it yet), if you share a folder over the network, that folder can NOT be accessed or modified from any other PCs or devices but only from the PC it had been shared on! I noticed this when sharing folders in external HDDs.
For example, if you share a folder (with say... 2TB of data) on a Windows PC, and somehow lose access to that computer, or simply want to use that external HDD (which contains the shared folder) on another computer, Windows won't let you open it and says "You do not have permission to access this folder".
2TB of data... just gone!
You can try that for yourself. That's the reason I avoid sharing folders like that in Windows.
Originally posted by Veronica View PostI have used that too and also XBMC file manager to copy/move files, but i realized is faster copy the file from my pc using windows explorer and a Native SMB server on Android side.
Originally posted by fikhl View PostYeah I'm still on 105k4. I've been putting off updating the firmware 'cause it's serving me just fine for now. This new build (109k4) is very tempting though. Might finally make the jump!
Exactly. Having the HDDs show up in Windows explorer as a network destination is just the best way to easily move files around. Which Android app do you use for SMB sharing?
On the other hand i've never shared folders from external hard drives connected to Windows pc so i see your point, but in my android box and linux mini pc is a different story, it works great and i have moved my hdd few times between them plus my Windows pc to copy files with no problems.
You should consider to buy a NAS or build/buy a dedicated inexpensive pc as a media server and use linux as the OS.
I only have 1 3tb hdd and still have more than 1tb of free space so no need to upgrade yet, but you already have 3 drives right?Last edited by Veronica; 01 October 2014, 02:07.
Originally posted by Veronica View PostI use Servers Ultimate app. I haven't had problems with Windows shares maybe you did not set the permissions right. I can access my windows shared folders from my android box via different kind of apps. ES file explorer, XBMC, etc and i can cut/move/rename/delete files if i wanted to. I have Windows 8.1 upgraded from Windows 8 but i don't think why Windows 7 shares would be different.
Sent from my Galaxy Note 3 using Tapatalk 2.Live as if you were to die tomorrow. Learn as if you were to live forever
I have an old netbook lying around gathering dust. I've been contemplating the idea of using it as a Linux media server but eventually decided to go the easy route and directly connecting the hard drives to the android box. Now I'm regretting it...
I currently have two 2TB drives, with about 1.5tb of free space. I'll give this Servers Ultimate app a shot and see how it goes.
Thanks for your input.
Originally posted by racky29 View Postwindows 8 has a quick hibernation feature, and wont let you access drives, you have to turn it off in windows power management, you should be ok then
windows 8 yuk
JustMeBugs are Sons of Glitches!
JustMe
Originally posted by JustMe View Postwindows 8 yuk
JustMe
Google it!
8 sucks the socks off the worst POS I have seen...... Lets hope 10 is better.....
I this off topic by far
win95 --- cannot remember first rls
win98 -good
mellinium - dud
win xp - good
vista - dud
win 7 - good
win 8 - dud
win 10 - ? to be seen
JustMe
Originally posted by Finless View PostWindows 10 is next SOON!
Google it!
my asus n750jv came with 8, i update to 8.1, and lost wifi, bluetooth and graphics card ( driver incompatabilty ) and system restore is not set to "on" by default so no rollback! aaarrrgh!
definately +++++++1 agree with your POS comment!!Sent from my Commodore 64 using Geos
My devices:
Tronsmart Vega S89-H: running stock 104k4 rom, rooted & racky's cpu fix.
Samsung Galaxy Tab 10.1: running KK's dual boot kernel, Phil's touch recovery & de-bloated, over-clocked and rooted stock rom.
Samsung Galaxy S3: stock until warrany is over lol running JB 4.3 ...
HTC Incredible S: Venom rom, 'kangaroo' kernel, overclocked to 2Ghz & still kicking the Sammy's butt!
There are currently 2858 users online. 1 members and 2857 guests.
