Sent from my GT-I9505 using Tapatalk
Stock Firmware - Beelink S82/M8 - MXIII 1/2G - Official FW Releases from Beelink - user feedback thread
I just checked 109K4
1) It is rooted already
2) The permissions are now set correctly so an "official" XBMC should work and you should get video!
Oman is on it.....
I had a problem last night updating to 109k4
I edited the .Aml script to include
--wipe_system
Now its installed perfectly first time, I'm using the same s82_109k4.zip and same sd card
So it may be the system wipe did the trick
One thing I noticed straight away is the notification tones are still broken.
Change the sound file to something else for notifications and see if that works. I think the default notification sounds are blank
They may have done that to not allow notifications to interrupt your video experience
Bob .. i have a slight issue .. when i plug in power supply . it just boots .. no way around that
Sent from my GT-I9505 using TapatalkLast edited by glenngaucigrech; 21 September 2014, 17:47.
2) I format data in the script so if you do not have the factory_update_param.aml on sdcard (which does the wiping if you use it right) it will still wipe the device.
Google Text To Speech
I updated to 109K4 Flash process went as expected but when it initially started It came up with a "Google Text to Speech Engine Failed to Start" I also get the " Allow google to check periodically for misbehaving apps. etc.. " this usually only comes up if you have your play store account linked. Just checking if others are also seeing this?
There are currently 2081 users online. 0 members and 2081 guests.
