Stock Firmware - Beelink S82/M8 - MXIII 1/2G - Official FW Releases from Beelink - user feedback thread
Google contacts and calendar now sync. The hide bottom tool bar icon is working. So far the hide the screen capture icon in the bottom tool bar can be hidden. No improvement in Netflix, but it does work OK streaming DVD quality.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Same here - still troubles with CEC - its loosing the "connection" from time to time ! (i have to switch the HDMI on the TV then or turn it off / on in the S802 Settings.
- Kodi Alpha 3 is still chrashing on my Beelink M8 H
- Netflix quality didn't change but i can live with that
- Calender and other google stuff works now - me like ;-)
Originally posted by it00x32 View Post- Calender and other google stuff works now - me like ;-)
Thanks Oman!
[Logcat] Amazon Prime Instant Video
I believe this is only valid for UK and Germany.
Amazon Prime Instant Video App seems to work but force closes when the player should launch. Could be a Java and/or a DRM thing (guessing).
Please have a look at the logcat .. possibly there is something to fix :-)
Please let me know if pastebin is inconvenient .. I can also provide the orginal txt file.
Another note: Currently only the Phone app is supported so I copied the apk from my Galaxy to the tronsmart. I do believe this worked in 108 but I could not swear on it (99% sure).
Logcat will expire in one week.
Originally posted by daniello9 View PostI believe this is only valid for UK and Germany.
583.09-20 18:54:09.772 8815 8815 I com.amazon.device.crashmanager.AppFileArtifactSour ce: Saving crash report to file: /data/data/de.amazon.mShop.android/files/crashlog.v2.amzcl
This seems to be the problem:
519.09-20 18:54:09.172 8815 8815 E AmazonVideo.events: EXCEPTION: java.lang.IllegalStateException: The popup window has to be present to handle Surface switching.
521.09-20 18:54:09.172 8815 8815 W dalvikvm: threadid=1: thread exiting with uncaught exception (group=0x416e3ba8)
523.09-20 18:54:09.172 8815 8815 E AmazonAppstore.GlobalExceptionHandler: Unhandled exception
525.09-20 18:54:09.172 8815 8815 E AmazonAppstore.GlobalExceptionHandler: java.lang.RuntimeException: java.lang.IllegalStateException: The popup window has to be present to handle Surface switching.
Thanks for taking a look.
Does this APP open a browser or something? Seems some issue there.
Also do you have xposed framework installed?
53.09-20 17:42:42.622 4218 4218 E AndroidRuntime: at de.robv.android.xposed.XposedBridge.main(XposedBri dge.java:132)
Might try without it if you do.
edit: xposed is not the culprit
[QUOTE=daniello9;229583 .. there is a parallel thread with others that have these kinds of problems on the round boxes:
...[/QUOTE]
aren't you also at the round one, or which one are you using?RK3288 Devices
- Overview BOX (LINK !)
There are currently 1646 users online. 0 members and 1646 guests.
