Stock Firmware - Beelink S82/M8 - MXIII 1/2G - Official FW Releases from Beelink - user feedback thread
Yes u did mention it .. if you can comfirm pls let me know
Sent from my GT-I9505 using TapatalkLast edited by glenngaucigrech; 02 January 2015, 15:22.
Not sure if this is just an S82 (2G/8G), thing... But, my M82 (1G/8G), Box has been solid throughout. 109k4, 110k4 and now on 111k4 w/SMBC 13.4.
What I'd like to know is IG 112k4 will land with Kodi (XBMC 14), or not.
On that note I really should give the standard Android Version a trail run.
But, if what I've been reading about in the OpenELEC Threads is anything to go by, then it would seem that modi is still not quite in Prime-Time yet.... (i.e. Unexplained dropouts in the Audio Channels. But, that could just be down to OpenELEC itself.)
But, on 111k4 everything is as much the same as it always was on this Box since I first got it Two Months ago now.
Originally posted by Ichijoe View PostNot sure if this is just an S82 (2G/8G), thing... But, my M82 (1G/8G), Box has been solid throughout. 109k4, 110k4 and now on 111k4 w/SMBC 13.4.
Maybe next ROM is based on Android 5.0Easy way to catch LOG -> Search 'Syslog' in Google Play,then install it and catch log
Originally posted by oman View PostI am not sure whether it's necessary to bump to 112k4 ..
I have no idea what Lollipop could, or would bring to the Table other then possible security fixes.
Speaking of which... Why are we still on Kit-Kat 4.4.2, and not Kit-Kat 4.4.4?!
Hi Oman,
Latest 111k4 video quality is seems perfect. Way better than previous releases.
Finally SPMC worked outofthebox.
I have two concers about this fw:
- is it possible to eliminate the suspend/power off menu, when pressing standby button on ir remote (old school method: 1-click standby was better)? Maybe an option in the Settings menu, to disable it?
- the biggest problem is: hdmi-signal problem. When I try to wake up the device from standby, it woke up, but AV receiver didn't get the signal from the box properly (it "sees" the box, but there's no AV-signal). Had to power off the box, because HDMI connection is not working properly. With 106k4 or 108k4 I have absolutely no such problem. Sometimes changing the input to another, and back, on my AV receiver solves the problem, but sometimes I have to power down the box.
Any chance to solve this two in next release?
Is there a simple solution for using (forexample) 106k4's files in latest ROM? I mean just to overwrite those files which are responsible HDMI handling (and standby/power off - pop-up)?
Originally posted by oman View PostMaybe next ROM is based on Android 5.0.
I know our box is not a smartphone, but Xiaomi managed to work a wake-up scheduler. It's awesome to wake-up the device on a specified time. Do you think it's possible to implement this feature into our box?
greetings,
eM
Originally posted by eM82 View Post- is it possible to eliminate the suspend/power off menu, when pressing standby button on ir remote (old school method: 1-click standby was better)? Maybe an option in the Settings menu, to disable it?
Originally posted by daniello9 View Post
There are currently 5094 users online. 1 members and 5093 guests.
