Stock Firmware - Beelink S82/M8 - MXIII 1/2G - Official FW Releases from Beelink - user feedback thread
RK3288 Devices
- Overview BOX (LINK !)
Originally posted by oman View PostFW Release->
The latest:
Compatible with S82/S82B/S82H+Ap6210/Ap6330 and MXIII(1G&2G DDR)+AP6181/AP6210/AP6330--->All IN ONE
Upgrade by TF card: Download Here(112k4)
112k4->
1.Add Flix Universe.apk
2.Add "Dolby settings" item at Settings
3.Support BT MAC customization
4.Fix the TureHD video broadcast problem
5.Fix the MPEG codec video broadcast problem
6.Fix Sony PS3 Bluetooth handle and the platform can not establish a Bluetooth connection, connection prompts "Segmentation fault"
7.Fix BOX sometimes cannot read Ethernet MAC
8.Fix HDMI sometimes has no image output
9.Fix sometimes soft shutdown crashing
111k4->(Based on AML latest official SDK(1114))
1.Update xbmc (Based on SPMC13.4.0 --Thanks to koying);
2.Update Skype;
3.Ethernet MAC (No need to modify Ethernet MAC by tool ,it can be produced by FW automatically and be unique)
4.Compatible with our R89 IR Remote;
5.UPdate DLNA&Airplay;
6.Fix some issues on some streaming APP,such as Hulu,BBC ..
7.Many fixes on multimedia playing..
8.Other little tweaks.
PS:
1.Some MXIII(2G) version would be without BT option with this FW.
109k4->
1.Optimization Power Consumption.
2.Improve stability issue When auto reboot,auto suspend,Monkey test,AV file continue playing.
3.Add protocol: UDP ,RTP , MMS ...
4.Update NAND/EMMC driver.
5.Fix some Wi-Fi throughput problem.
6.Support Antutu videobench apk.
7.Optimization display effect for HDMI.
8.Support new feature DRM,Playready L1/L3,Widewine.
9.Add Secure OS.
10.Visit America websit netflix and youtube smoothly.
11.Strengthen encoder stability.
12.Change the Mxplayer to normal version;
13.Update xbmc to Gotham 13.2,and open some nodes' authority,so you can install any version of xbmc;
14.Make the physic power-key to be suspend/resume working by short press,and long press (5s) to shutdown;
15.Remove the Popup notification when xbmc/Mxplayer/... been ran at the first time;
16. Add an Icon to show/hide Status Bar;
17.Support Hausbell Mmini i8 and Rii Mini H7 air-mouse;
18. Make some portrait APPs to be showed to landscape,such as Antutu;
19.Fix issue:the A/V Async for MPEG2;
20. Fix issue:it may auto-wakeup when in suspend state;
21.Fix issue:the usb port may lose efficacy after resume;
22. Fix issue:no sound for Notification;
23. Improve some parts of MBXLanucher;
24.Fix issue:Google Calendar/People cant sync.
108K4->
1.Add 1080P24Hz support;
2.Support for NTFS/CIFS; --Offered by wasser
3.Change Input method to Latin,and remote can use;
4.Update Play Store;
5.Support for Mele F10 air-mouse; --Pulled from Bob's FW
6.Support for Xbox/PS3; --Offered by Bob
7.Change method of Root access; --Offered by leolas
8.Add kill-recent-task function; --Offered by daemonium
9.Update xbmc to Gotham 13.1,fix 4k playback and 2160P/720P HDMI display issue; --THX stane
10.Add remote function in Recovery Mode;--THX leolas
11.Adjust MBXLauncher,add Yahoo wether and Clean-Memory function,fix slow animation issue;
12.Fix issue->Power-key of Remote might lead to reboot;
13.Improve small probable of blurred screen.
107k4->
1.Add for CPBLTV live stream;
2.Decoding Dts/Dolby for S802;
3.Add suspend and Power-off function by Remote or power button from Status Bar;
4.Add root access permission.
106k4->
1.Enhance system stability;
2.It can flash Ethernet MAC;
3.Enhance the power of 4k video decoding;
4.Fix issue of 1080i video playing.
105k4->
1.Fix some LiveTV apk can't be ok;
2.Optimize Thermal control;
3.Optimize HDMI/AV;
4.Optimeze Launcher/Settings,use only 1080P UI;
5.Fix video burning test fail;
6.Support secure OS function;
7.Update NAND driver;
8.Support APK installation to external SD.
103k4->
1.Better xbmc for playing 4k video;
2.6210_8G compatible with 6330_16G,to be the same FW;
3.Add PPPoE;
4.Adjust thermal control,Special for Antutu;
5.Adjust HDMI signal to more TV compatible;
102k4->
1.Better xbmc,no async between audio and video ;
2.Fix 5G wifi compatibility;
3.Better for Antutu benchmark;
4.S802/S802B/S802H are all compatible;
5.Other little tweaking.
TOOLs:
Update tools by USB: USB_Burning_Tool_v2.0.4_x86 --> support win8
How to upgrade FW By TF card:
1.Unzip the zip/rar file,and copy 3 files(105k4.zip,recovery.img,factory_update_param. aml) to TF card Root directory;
2.Plug in the TF card and Power line,then pressing the button in the AV hole,then press power button,then release button in the AV hole.
3.OK,it will be into update process.
112 - audio detection?
I was wondering if the auto audio detection works with 112, Bluetooth?
I have spdif input to my stereo, nice when I turn in on if it auto detect.
I was on 108 and everything worked great, then I went for 111, only improvement was that I could hide status bar without going in to settings.
Originally posted by Hoffes_tp View PostHi,
can someone test if Prime Instant Video ist working with 112k ?
Because with 111k it is not working
Brgds
Originally posted by Mywaruk View PostIv installed this from 108k4 with twrp for 109k4 and lower, after installig 112k4 i can longer boot into android recovery or twrp, just boots to home screen, any ideas? iv been told to reinstall twrp but i cant get into any recovery.
Cheers
Did noticed recovery was missing from the rom so i would grab the one from 111k.
Edit: seems the download having issues and sometimes cutting off before completion.Mk802IV Neomode 1.9a original rom 720p
Ooook, backup and running with TWRP, managed to restore my orginal backup when first got it 108k4, only problem i have now is ethernet will not detect a connection, rebooted modem few times to make sure but nothing... was working fine on112k4.
UPDATE: Launched TWRP from SD, installed TWRP, Rebooted, Installed 112k4, did the wipe, all seems great now! ethernet back, lost bluetooth but i dont mind that as i never used it for anythingthanks for everyone who get me through this
I don't know if it is related but I was planning on troubleshooting slow Wi-Fi speeds with an S82B, speeds were much improved after the update to 112k4 and I didn't have to do anything. I am not going to revert to the old firmware to test further but as far as I am concerned, this new firmware is an improvement for the things I do, at least so far.
Originally posted by hereje View PostSince 111k4, sometimes when I suspend my Vega S89 I can't turn it up again, I have to press the power button 5 seconds to turn it off so I can turn it up again. I was hoping the 112k fixed that
Does this only happens to me? or in every Tronsmart Vega?
I have same problem with 111k4. Actually it is switched on (with blue LED), but no video signal, so u think u cannot turn on again and need to reset.. If you blindly press the IR remote power buttons, you still can suspend it again..
Upgraded to 112k4 for a few days , seems ok ..
I guess this is fixed...?
There are currently 1755 users online. 0 members and 1755 guests.
