Is there any way to prevent my M82 (1G/8G - AP-6181 MXIII), from creating a new "Device" under my Google Music Account every time I need to update it? Is the S82 as buggy when it comes to this? Is there a "Box" that can keep its "Identity" after such "Updates"? I really need to be able to continue to use my GMusic Account. But, these Updates are like a time-bomb just waiting to go off again. Since Google have now limited the ability to deactivate only Four Devices per Year. And I've already got rid of Two of 'em.
Stock Firmware - Beelink S82/M8 - MXIII 1/2G - Official FW Releases from Beelink - user feedback thread
Q: To Mr Oman
NEED HELP!!!
Hello Oman, Im new here
I have mxiii 2gb and last night my tv box is auto update now there's a slight problem, when i start to open you will see the black screen only please help me thanks
Originally posted by oman View PostXBMC->
The latest Gothom 13.1 release version,can be used on s802 platform:
Download Here:xbmc-13.1-Gotham-armeabi-v7a-oman
xbmc-13.1-Gotham-4K-video-2160P-output->
based on xbmc-13.1-Gotham-armeabi-v7a
1.Decode 4K video;
2.Fix playing video 1/4 issue when HDMI 2160P output;
Download Here:xbmc-13.1-Gotham-4K-video-2160P-output
They are still at 108k, I read a lot of problems with this S89 and problems with each firmware version ... I do not believe in these devices will become reliable
And do not think I buy another Tronsmart or 'Beelink ....
109k4 FW for SD card
Dear Oman,
Can you please send me a link so i can download the 109k4 FW perferably for an SD card?
Thanks!
Originally posted by oman View PostFW Release->
The latest:
Compatible with S82/S82B/S82H+Ap6210/Ap6330 and MXIII(1G&2G DDR)+AP6181/AP6210/AP6330--->All IN ONE
Upgrade by TF card: Download Here(112k4)
112k4->
1.Add Flix Universe.apk
2.Add "Dolby settings" item at Settings
3.Support BT MAC customization
4.Fix the TureHD video broadcast problem
5.Fix the MPEG codec video broadcast problem
6.Fix Sony PS3 Bluetooth handle and the platform can not establish a Bluetooth connection, connection prompts "Segmentation fault"
7.Fix BOX sometimes cannot read Ethernet MAC
8.Fix HDMI sometimes has no image output
9.Fix sometimes soft shutdown crashing
111k4->(Based on AML latest official SDK(1114))
1.Update xbmc (Based on SPMC13.4.0 --Thanks to koying);
2.Update Skype;
3.Ethernet MAC (No need to modify Ethernet MAC by tool ,it can be produced by FW automatically and be unique)
4.Compatible with our R89 IR Remote;
5.UPdate DLNA&Airplay;
6.Fix some issues on some streaming APP,such as Hulu,BBC ..
7.Many fixes on multimedia playing..
8.Other little tweaks.
PS:
1.Some MXIII(2G) version would be without BT option with this FW.
109k4->
1.Optimization Power Consumption.
2.Improve stability issue When auto reboot,auto suspend,Monkey test,AV file continue playing.
3.Add protocol: UDP ,RTP , MMS ...
4.Update NAND/EMMC driver.
5.Fix some Wi-Fi throughput problem.
6.Support Antutu videobench apk.
7.Optimization display effect for HDMI.
8.Support new feature DRM,Playready L1/L3,Widewine.
9.Add Secure OS.
10.Visit America websit netflix and youtube smoothly.
11.Strengthen encoder stability.
12.Change the Mxplayer to normal version;
13.Update xbmc to Gotham 13.2,and open some nodes' authority,so you can install any version of xbmc;
14.Make the physic power-key to be suspend/resume working by short press,and long press (5s) to shutdown;
15.Remove the Popup notification when xbmc/Mxplayer/... been ran at the first time;
16. Add an Icon to show/hide Status Bar;
17.Support Hausbell Mmini i8 and Rii Mini H7 air-mouse;
18. Make some portrait APPs to be showed to landscape,such as Antutu;
19.Fix issue:the A/V Async for MPEG2;
20. Fix issue:it may auto-wakeup when in suspend state;
21.Fix issue:the usb port may lose efficacy after resume;
22. Fix issue:no sound for Notification;
23. Improve some parts of MBXLanucher;
24.Fix issue:Google Calendar/People cant sync.
108K4->
1.Add 1080P24Hz support;
2.Support for NTFS/CIFS; --Offered by wasser
3.Change Input method to Latin,and remote can use;
4.Update Play Store;
5.Support for Mele F10 air-mouse; --Pulled from Bob's FW
6.Support for Xbox/PS3; --Offered by Bob
7.Change method of Root access; --Offered by leolas
8.Add kill-recent-task function; --Offered by daemonium
9.Update xbmc to Gotham 13.1,fix 4k playback and 2160P/720P HDMI display issue; --THX stane
10.Add remote function in Recovery Mode;--THX leolas
11.Adjust MBXLauncher,add Yahoo wether and Clean-Memory function,fix slow animation issue;
12.Fix issue->Power-key of Remote might lead to reboot;
13.Improve small probable of blurred screen.
107k4->
1.Add for CPBLTV live stream;
2.Decoding Dts/Dolby for S802;
3.Add suspend and Power-off function by Remote or power button from Status Bar;
4.Add root access permission.
106k4->
1.Enhance system stability;
2.It can flash Ethernet MAC;
3.Enhance the power of 4k video decoding;
4.Fix issue of 1080i video playing.
105k4->
1.Fix some LiveTV apk can't be ok;
2.Optimize Thermal control;
3.Optimize HDMI/AV;
4.Optimeze Launcher/Settings,use only 1080P UI;
5.Fix video burning test fail;
6.Support secure OS function;
7.Update NAND driver;
8.Support APK installation to external SD.
103k4->
1.Better xbmc for playing 4k video;
2.6210_8G compatible with 6330_16G,to be the same FW;
3.Add PPPoE;
4.Adjust thermal control,Special for Antutu;
5.Adjust HDMI signal to more TV compatible;
102k4->
1.Better xbmc,no async between audio and video ;
2.Fix 5G wifi compatibility;
3.Better for Antutu benchmark;
4.S802/S802B/S802H are all compatible;
5.Other little tweaking.
TOOLs:
Update tools by USB: USB_Burning_Tool_v2.0.4_x86 --> support win8
How to upgrade FW By TF card:
1.Unzip the zip/rar file,and copy 3 files(105k4.zip,recovery.img,factory_update_param. aml) to TF card Root directory;
2.Plug in the TF card and Power line,then pressing the button in the AV hole,then press power button,then release button in the AV hole.
3.OK,it will be into update process.
Originally posted by ronylen1 View PostDear Oman, Can you please send me a link so i can download the 109k4 FW perferably for an SD card? Thanks!
1) Ethernet (Port), Speeds have seemed to have taken a turn for the worse ever since 111k4. I've seen some Posts already about this. Though I kinda dismissed it at the time. I'm now on the side of believing it!
2) The Antutu Video Test, Although I had to sideload this Benchmark on 109k4 (M82 1G/8G AP6181 MXIII Box),. I was fairly confident that I could have at least gotten though the WMV2, and Real Media (Cooker?!), Parts with out the complete drop in Video, as has been, and continues to be the case since 110k4 ~ 112k4. Which is on the whole quite odd given that this "Update" was supposed to actually improve Video!
Just a thought to Mr Oman.... Is it really a good idea to keep up with these All In One Packages?
I mean on the Face of it... I can understand why this would be a preferred method.
But, not everyone with a MXIII cough M82, has the more preferred S82. And it starting to seem to me that this AIO Setup is showing signs of strain.
The Clock Bug for One... I can't say if its just an S82 thing...
But, on my M82 I've never seen it. EVER! And, yes I'm currently on 112k4 ATM!
With all the "optimization" going on for the S82 (e.g. 2G/8G+Bluetooth units), which actually still suffer the broken Bluetooth Bug! (Not really wanting to get me to upgrade my M82 (1G/8G BTW),.
I'm not feeling much support coming for the M82, and a lot of misplaced hand-me-downs from the S82, side of things.
I do understand that these ARE fundamentally the SAME Devices.
But, when it comes to tweaking the Memory Buffers, for Live Internet Streams, Have those same "Tweaks" been modified for the 1G Versions, since they obviously only have 1G of RAM, its not possible to use 2G, as was suggested in such posts. 'Cause the 1G (M82), seems to preform rather badly at live streaming....
Perhaps its down to different priorities? I don't know. But, I think having separate M82 / S82 Branches was a better idea... User Side...
P.s. BTW you can find the 109k4 AP-6181 Firmware here.... Those with the RTL8188 will have to look elsewhere! http://www.file-upload.net/download-...dcard.rar.html
One other Note.... YOU WILL HAVE TO ALSO DOWNLOAD AND INSTALL THE USB BURNER TOOL! To downgrade your Device. As otherwise you'll receive an error in the 3E Recovery stating that you can not install an older Firmware i.e. 109k4 over a newer One e.g. 112k4.
So keep that in mind!
P.p.s. I forgot that the Link is as you wished it a SD Zip File. Problem is to downgrade you'll need a *.img File So to actually downgrade, you'll probably need to stock Beelink Firmware 108k4 first. Which you can still find over on their Website. Yeah its the RTL8188 Version. So WiFi will NOT WORK. But, its still useful as a transition to the 109k4 AP6181 that does.
The only ballache I have about it is my Google Music Account. Otherwise I'd be doing this myself.Last edited by Ichijoe; 22 January 2015, 15:10.
Originally posted by vermillion View PostMy Ethernet connection has been vastly improved by fixing my ip via static ip in Ethernet settings and reserving the ip in my dchp router.
This should make no difference but it does.
There are currently 3842 users online. 0 members and 3842 guests.
