Stock Firmware - Beelink S82/M8 - MXIII 1/2G - Official FW Releases from Beelink - user feedback thread
A little help please
My new box arrived but I'm struggling to get wifi to work (MXIII 1Gb 108K4 factory install). Wifi box stays greyed out when switched on and when I go back to it, is back in off position. I'm yet to see any wireless signal at all.
I thought maybe upgrading to newer firmware might help but have tried both 108K4 and 109K4 on page 1 via TF method and they both hang at about 25% of the way through.
Any help would be most welcome.
Re: Important - Stock Firmware - Beelink S82/M8 - Official FW Releases from Beelink - user feedback thread
Originally posted by mrlentle View PostMy new box arrived but I'm struggling to get wifi to work (MXIII 1Gb 108K4 factory install). Wifi box stays greyed out when switched on and when I go back to it, is back in off position. I'm yet to see any wireless signal at all.
You can't (but often told) because the 1GB version use another WiFi-Chip which is not supported by this rom for round and 2GB devices...RK3288 Devices
- Overview BOX (LINK !)
Once I get my S89-H, count me in. I'm a UNIX/Linux systems administrator, and I'll gladly report, as verbose as I can.
Originally posted by Finless View PostOK here is the updated 109K4 flashable ZIP format ROM.
1) I removed the assertion check at the front of the script so this will install on any S802 device. It will not check what version you have installed already. So you know an assertion check usually checks the device model and the version currently installed. Again this is removed now.
2) I format data in the script so if you do not have the factory_update_param.aml on sdcard (which does the wiping if you use it right) it will still wipe the device.
No other changes
DO NOT DOWNLOAD THIS AND PUT THIS ZIP ON SDCARD!
Unzip this download and you will have the package in a folder called 109k4_stock_rom_prerelease.
In it is the files needed and instructions explaining several ways in which to flash this ROM.
ROM -> Tronsmart S89/S89H & Beelink S82/S82H/M8 - 109K4 Stock ROM Pre-release (401 megs)
Note: I will wait until Oman says this is "official" or releases an "official" 109K4 ROM before I make a Finless 2.0 ROM from it. So please don't ask until then.
Sent from my GT-I9505 using Tapatalk
Originally posted by Hoffes_tp View Post@Oman,
do you know why Amazon Prime Instant Video is not working on Beelink Devices?
It should integrates widevine from Google or something from Media Content providers..
Originally posted by scooter2014 View PostThe new rom does not have improved codex for amilogic????Easy way to catch LOG -> Search 'Syslog' in Google Play,then install it and catch log
Bell TV APP
=> http://www.freaktab.com/showthread.p...android-tv-boxRK3288 Devices
Originally posted by oman View PostThe 109k4 ROM just support DRM,but that's not mean it can decode any DRM media content from Netflix/Hulu/BBC iPlayer/....
Originally posted by WeK05 View PostFrom logcat, it seems that Amazon Instant Video is failing due to lack of Chromium integration. The app is calling for http streaming using Chromium. This is how Netflix works on Amazon Firetv (HTML5 streaming). Amazon is using a similar method for their instant video.
http://www.freaktab.com/showthread.php?14583-Netflix-HD-Playback&p=230408#post230408
JustMeBugs are Sons of Glitches!
JustMe
Originally posted by JustMe View Postread my last post new firmware has improved bitrate and resolution but just short of hd
JustMeMk802IV Neomode 1.9a original rom 720p
There are currently 2248 users online. 1 members and 2247 guests.
