Sent from my GT-I9505 using Tapatalk
Stock Firmware - Beelink S82/M8 - MXIII 1/2G - Official FW Releases from Beelink - user feedback thread
AW: Important - Stock Firmware - Beelink S82/M8 - Official FW Releases from Beelink - user feedback thread
@all
Originally posted by clarkss12 View PostI have the Vega S89H and I am very pleased with it. I use both SPMC, latest version, and the current nightly build of Kodi
. they both play every thing I throw at it. The only video that struggles a little bit, is streaming live TV in mpeg2 TS format. But only the 720P channels drop frames, and they are not noticeable. I only know they drop frames because I use the diagnostic overlay to see them. The 1080i streams on the other hand have no dropped or skipped frames.
Just my opinion.fullhd and rest is workin like before.....
Originally posted by Magnus33 View PostLooks like video/audio sync issues are streaming related rather then codec related.
has audio/video issues with HW decoding ON, and NO ISSUES with HW decoding OFF.
So it's not fully streaming related!
Please, could anyone try this also?
Originally posted by Biatsch View Post@all
Damn he's so right.... No problems (stuttering) on xvids anymore with latest spmcfullhd and rest is workin like before.....
xbmc-14.0-Helix alpha2
Welcome
I have a question about XBMC 13.2 Gotham and now I would like to have XBMC-14.0-Helix ALPHA2, how can you do the upload (108k4) and I had uploaded 104k4 and the old version I had XBMC-14.0-Helix ALPHA2 and please help
Many thanks for your helpLast edited by Bogdan16; 14 October 2014, 13:18.
Bluetooth
Hey all and gratz for the amazing work done here. I have flashed Oman's 109k4 fw to my MX III 2g box and it's quite impressive. The only glitch observed so far is that there is no bluetooth in settings, making bluetooth unusable. Same applies for finless 2.0. I tried Stane's latest fw and bluetooth is back and working. (tried both clean and dirty flash). Is this a known issue or just a problem at my end? Any input-solution is appreciated.
Cheers
Originally posted by apos View PostHey all and gratz for the amazing work done here. I have flashed Oman's 109k4 fw to my MX III 2g box and it's quite impressive. The only glitch observed so far is that there is no bluetooth in settings, making bluetooth unusable. Same applies for finless 2.0. I tried Stane's latest fw and bluetooth is back and working. (tried both clean and dirty flash). Is this a known issue or just a problem at my end? Any input-solution is appreciated.
CheersMinix Neo X7 - Wasser 1.0.4 OC'd - Kodi-helix with passthrough
Beelink M8B - Wasser 1.0.3 - Kodi-helix alpha 2 + SPMC
Xmbc out of sync and with the likes of say mxplayer it works fine.
I think the problem is that these files themselves.
The older the format used to make them the less likely players are going to support them.
A good example is the wd smp player which plays everything but has issues with older mpeg formats that are just no longer used.
I had problems with older loony tunes files myself which were made with older software.
I just batch converted the lot of them to a newer format since there small files to begin with.
It is clear that local codec support is outdated and a patched mess tough so its needs updating regardless.Last edited by Magnus33; 14 October 2014, 16:47.Mk802IV Neomode 1.9a original rom 720p
Originally posted by ant View PostAfaik bluetooth and wifi don't work at the same time, so disable 1 of the functions to get the other to operate.
Originally posted by apos View PostThanks for your answer but the problem persists. Tried disabling the wifi but there is still no bluetooth setting, therefore there is no way to control bluetooth.
[ATTACH=CONFIG]8392[/ATTACH]
I can now see there is not option to use / control the Bluetooth from setting menu.
Secondly I'm now at home and can potentially see the issue
The build.prop from 109k4 has this line:
Code:#used in packages/apps/Settings/.../Utils.java hw.has.bluetooth=false
Using a build.prop editor you could try editing from:
Code:hw.has.bluetooth=false
Code:hw.has.bluetooth=true
Hope this helpsMinix Neo X7 - Wasser 1.0.4 OC'd - Kodi-helix with passthrough
Originally posted by Veronica View Postthats weird i just checked and i do have bluetooth under wifi. what box do you have?Minix Neo X7 - Wasser 1.0.4 OC'd - Kodi-helix with passthrough
Hope this helps
Is it possible it has to do with the flashing procedure? I have read in the MXIII thread that ppl are using this firmware successfully, so I guess it is not the box model that is incompatible.
Cheers
There are currently 2426 users online. 0 members and 2426 guests.
