Stock Firmware - Beelink S82/M8 - MXIII 1/2G - Official FW Releases from Beelink - user feedback thread
Originally posted by scooter2014 View PostWhy what needs to be fixed now???? Had a ton of fixes and this box is rocking smooth and fast now so releases have been steady and just got 109 release now you want 110???
maybe btime for some custom roms to hopefully have these changes in them weeeeeeeeeee. finless 20 running very well on these.
There also a few minor ones like trouble with ps3 controllers/Bluetooth.
The codecs are in major need of updating also.
Otherwise the firmware is very solid and stable.
Now if i could say the same for my neighbor.Mk802IV Neomode 1.9a original rom 720p
Re: Important - Stock Firmware - Beelink S82/M8 - Official FW Releases from Beelink - user feedback thread
Originally posted by Magnus33 View PostThe only major issue at the moment is a the video sync issue which seems to be related to resolution and bandwidth.
Originally posted by londonshore View PostSo u are using omans stock 109 rom and what xbmc? ... and what device because im thinking on my s82 older roms worked better but it could only be me and im using xbmc 13.2
As to which xbmc works it varies it depends but spmc seems to be the happiest.Mk802IV Neomode 1.9a original rom 720p
Originally posted by londonshore View PostSpmc?
The google fork of xbmc.
They are testing to see if google ok with xbmc on google play store to see if google ok with it.
Google goes after people who use certain codecs without payment but xbmc is open-source and free so google likely not to care.
Also upgrades like any other app.Mk802IV Neomode 1.9a original rom 720p
File
Originally posted by Merrickville View PostCould you post the path/filename where you entered this info?
Originally posted by dankec View PostCould someone please compare Finless 2.0 + SPMC to Stane's AMLinux XBMC firmware in term of smoothness...
I'm willing to migrate from AMLinux to Finless if there will be no problem with choppiness/stuttering when playing xvid in xbmc.
Please, someone?
Local playback for the most part works but streaming goes pear shaped with sync and stuttering issues.
Think its part codec/bandwidth and resolution this time.
With plex i get sync issue/stutering at times but can normally fix this by jumping back a bit in the video.
Does it happen on all xvid you got or just certain ones?Mk802IV Neomode 1.9a original rom 720p
Originally posted by ganjero View PostI am running the 109k4 on the new MXIII...do these little boxes have issues sending audio through the HDMI to a digital receiver? I can get it to send sound to the tv but not my receiverMinix Neo X7 - Wasser 1.0.4 OC'd - Kodi-helix with passthrough
Beelink M8B - Wasser 1.0.3 - Kodi-helix alpha 2 + SPMC
Originally posted by JockeSve View PostHere come the noob question of the week:
Is 109K4 rooted?
As far as I can see it says it for 108K4 but I can't find info about 109K4: 7.Change method of Root access; --Offered by leolas
But afaik finless worked out the "hard root" method not leolas....
He found out the technique so it doesn't get "broken" when installing some apps or changing a kernel, if your interested?
So if you don't want root you need to edit init.rc from within the boot.img and uninstall su. Maybe not possible to do this from the box though (edit boot.img) I do mods to boot.img on a pc then repack > sign > flashLast edited by ant; 11 October 2014, 00:13.Minix Neo X7 - Wasser 1.0.4 OC'd - Kodi-helix with passthrough
There are currently 1804 users online. 1 members and 1803 guests.
