Stock Firmware - Beelink S82/M8 - MXIII 1/2G - Official FW Releases from Beelink - user feedback thread
    Originally posted by ganjero View Post
    Yes...same issue no sound going to the receiver through the hdmi
    My setup -
    hdmi to tv from android box
    hdmi from tv to digital receiver
    Passthough selected in android + xbmc settings.
    Maybe try a different hdmi lead? Or different hdmi input(s) I had problems a while back with my x7 and the HDMI/AVI input on my tv, a software update on my tv finally sorted out my problems.
    Minix Neo X7 - Wasser 1.0.4 OC'd - Kodi-helix with passthrough
    Beelink M8B - Wasser 1.0.3 - Kodi-helix alpha 2 + SPMC
      I am running the 109k4 on the new MXIII...do these little boxes have issues sending audio through the HDMI to a digital receiver? I can get it to send sound to the tv but not my receiver
      With 109k4 running on my S89H through my A/C receiver via HDMI, I get Dolby and DTS.
        +1 me also
        Live as if you were to die tomorrow. Learn as if you were to live forever
          Hi.
          I going to by this device, ( or the S002 ) but i wonder if you can respond at 2 questions about it?
          The mane use for this to me going to be XBMC.
          How it is handles with XBMC?
          Are you satisfied with the box?
            I am having some more issues on the MXIII box and the 109k4. I have some q's, when you install with the card, does it matter if you have other files in the root directory? also on this box where is the "AV Button"? I could not find it so I updated to 109k4 using the update feature in the box.
            I just want to make sure my issues have nothing to do with the installation.
            Issues:
            -The box freezes specially while exploring the play store
            -Box freezes while using XBMC (using livestreams and genesis)
              Issues:
              The reset button in the av hole just stick a toothpick or like in there and you shall feel the click.
              Freezing should not be happening try reflashing.
              Mk802IV Neomode 1.9a original rom 720p
                Thanks, just reflahsed the way posted in the first post. Let's see if that gets rid of the freezing issues.
                  Originally posted by pajopasa View Post
                  Hi.
                  I have the Vega S89H and I am very pleased with it. I use both SPMC, latest version, and the current nightly build of Kodi
                  . they both play every thing I throw at it. The only video that struggles a little bit, is streaming live TV in mpeg2 TS format. But only the 720P channels drop frames, and they are not noticeable. I only know they drop frames because I use the diagnostic overlay to see them. The 1080i streams on the other hand have no dropped or skipped frames.
                  Just my opinion.
                    Originally posted by warken View Post
                    Hm...
                    really don't know why i can't sign in!? My username and password are ok.
                    The same problem was on 108k4 also.
                    Edit:
                    i just updated to the new version of skype and now i can sign in.
                    please use and try diferent skypes.a have the same in other droid devices.
                    you need to download other skype.or the best way is custom skype
                      Originally posted by ant View Post
                      A little bit of a late reply maybe, but yes 109k4 is rooted.
                      But afaik finless worked out the "hard root" method not leolas....
                      He found out the technique so it doesn't get "broken" when installing some apps or changing a kernel, if your interested?
                      So if you don't want root you need to edit init.rc from within the boot.img and uninstall su. Maybe not possible to do this from the box though (edit boot.img) I do mods to boot.img on a pc then repack > sign > flash
                      Thanks!
                      "Hard root"? I dont know what that means and I'm not sure I need to know!
                        I know what hard Brick means!!!!
                          Re: Important - Stock Firmware - Beelink S82/M8 - Official FW Releases from Beelink - user feedback thread
                          Originally posted by oman View Post
                          FW Release->
                          The latest:
                          Upgrade By USB: Download Here(108k4)
                          Upgrade By TF card:Download Here(108k4)
                          Upgrade by TF card:Download Here(109k4)
                          109k4->
                          1.Optimization Power Consumption.
                          2.Improve stability issue When auto reboot,auto suspend,Monkey test,AV file continue playing.
                          3.Add protocol: UDP ,RTP , MMS ...
                          4.Update NAND/EMMC driver.
                          5.Fix some Wi-Fi throughput problem.
                          6.Support Antutu videobench apk.
                          7.Optimization display effect for HDMI.
                          8.Support new feature DRM,Playready L1/L3,Widewine.
                          9.Add Secure OS.
                          10.Visit America websit netflix and youtube smoothly.
                          11.Strengthen encoder stability.
                          12.Change the Mxplayer to normal version;
                          13.Update xbmc to Gotham 13.2,and open some nodes' authority,so you can install any version of xbmc;
                          14.Make the physic power-key to be suspend/resume working by short press,and long press (5s) to shutdown;
                          15.Remove the Popup notification when xbmc/Mxplayer/... been ran at the first time;
                          16. Add an Icon to show/hide Status Bar;
                          17.Support Hausbell Mmini i8 and Rii Mini H7 air-mouse;
                          18. Make some portrait APPs to be showed to landscape,such as Antutu;
                          19.Fix issue:the A/V Async for MPEG2;
                          20. Fix issue:it may auto-wakeup when in suspend state;
                          21.Fix issue:the usb port may lose efficacy after resume;
                          22. Fix issue:no sound for Notification;
                          23. Improve some parts of MBXLanucher;
                          24.Fix issue:Google Calendar/People cant sync.
                          108K4->
                          1.Add 1080P24Hz support;
                          2.Support for NTFS/CIFS; --Offered by wasser
                          3.Change Input method to Latin,and remote can use;
                          4.Update Play Store;
                          5.Support for Mele F10 air-mouse; --Pulled from Bob's FW
                          6.Support for Xbox/PS3; --Offered by Bob
                          7.Change method of Root access; --Offered by leolas
                          8.Add kill-recent-task function; --Offered by daemonium
                          9.Update xbmc to Gotham 13.1,fix 4k playback and 2160P/720P HDMI display issue; --THX stane
                          10.Add remote function in Recovery Mode;--THX leolas
                          11.Adjust MBXLauncher,add Yahoo wether and Clean-Memory function,fix slow animation issue;
                          12.Fix issue->Power-key of Remote might lead to reboot;
                          13.Improve small probable of blurred screen.
                          107k4->
                          1.Add for CPBLTV live stream;
                          2.Decoding Dts/Dolby for S802;
                          3.Add suspend and Power-off function by Remote or power button from Status Bar;
                          4.Add root access permission.
                          106k4->
                          1.Enhance system stability;
                          2.It can flash Ethernet MAC;
                          3.Enhance the power of 4k video decoding;
                          4.Fix issue of 1080i video playing.
                          105k4->
                          1.Fix some LiveTV apk can't be ok;
                          2.Optimize Thermal control;
                          3.Optimize HDMI/AV;
                          4.Optimeze Launcher/Settings,use only 1080P UI;
                          5.Fix video burning test fail;
                          6.Support secure OS function;
                          7.Update NAND driver;
                          8.Support APK installation to external SD.
                          103k4->
                          1.Better xbmc for playing 4k video;
                          2.6210_8G compatible with 6330_16G,to be the same FW;
                          3.Add PPPoE;
                          4.Adjust thermal control,Special for Antutu;
                          5.Adjust HDMI signal to more TV compatible;
                          102k4->
                          1.Better xbmc,no async between audio and video ;
                          2.Fix 5G wifi compatibility;
                          3.Better for Antutu benchmark;
                          4.S802/S802B/S802H are all compatible;
                          5.Other little tweaking.
                          TOOLs:
                          Update tools by USB:
                          USB_Burning_Tool_v2.0.1_x86
                          How to upgrade FW By TF card:
                          1.Unzip the zip/rar file,and copy 3 files(105k4.zip,recovery.img,factory_update_param. aml) to TF card Root directory;
                          2.Plug in the TF card and Power line,then pressing the button in the AV hole,then press power button,then release button in the AV hole.
                          3.OK,it will be into update process.
                          Oman .. i have an issue and i tried wverything cant get out of it . I updated an m8 to 109k4 .. its amazing .. but remote dont work ...roundish remote .. then i kept reading and foudn a remote update by justme ...wich made the remote work .. while device is on .. but once u switch off the box u have no way to tuen it back on even from sleep mode .. u have to unplug it and replug it to turn it on ... any ideas?
                          Sent from my GT-I9505 using Tapatalk
                            There not a huge difference as far as i can see.
                            Local playback for the most part works but streaming goes pear shaped with sync and stuttering issues.
                            Think its part codec/bandwidth and resolution this time.
                            With plex i get sync issue/stutering at times but can normally fix this by jumping back a bit in the video.
                            Does it happen on all xvid you got or just certain ones?
                            Mostly on all 720p.
                            There's also sync problem with some SD videos when HW decoding is on. Here's example:
                            Please, could you download it and forward the result?
                              Originally posted by JockeSve View Post
                              Thanks!
                              Haha guys!
                              Basically it's hard to break root using bobs method....
                                Has anyone experienced random freezings and/or problems with media playback, like youtube app giving an error while trying to play a video or android media process crashing?
